Software Archive
Read-only legacy content
17060 Discussions
Parallel Studio 2015 Composer Trial - Enable Trusted Storage failed on x64
Ralf_K_
works fine while using x86 but when i try to compile to x64 i get this error:
error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
(VS Studio 2013)
Any ideas?
Regards Ralf
Hubert_H_Intel
Ralf,
I saw this error too with activating eval licenses, but couldn't identify the root cause yet. An alternative solution would be to use the license file for product instalaltion/activation. I'll send it to you offline. Please restart the installer and use the license file then (Activation Option: 'Alternative optiones > Use license file').
Regards, Hubert.
Ralf_K_
Hi Hubert,
thanks for sending the lic file and your support.
It works now.
Ralf
Matt_E_
Had the same problem with x64 as Ralf. Resolved by first running icl from a command prompt running as Administrator. "Intel Parallel Studio 2015 > Compiler and Performance Libraries > Command Prompt with Intel Compiler > Intel 64 Visual Studio 2013 mode".
