Software Archive
Read-only legacy content
17061 Discussions
Trouble with Flexlm license manager
Ben_Y_
I've never used this so please bear with me...
I've installed the license manager, and this is what I get when I run lmgrd:
14:57:44 (lmgrd) FlexNet Licensing (v11.11.1.1 build 119913 x64_lsb) started on pastec.gtri.gatech.edu (linux) (1/20/2014)
14:57:44 (lmgrd) Copyright (c) 1988-2013 Flexera Software LLC. All Rights Reserved.
14:57:44 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
14:57:44 (lmgrd) License file(s): /opt/intel/flexlm/server.lic
14:57:44 (lmgrd) lmgrd tcp-port 28518
14:57:44 (lmgrd) Starting vendor daemons ...
14:57:44 (lmgrd) Started INTEL (internet tcp_port 53992 pid 20391)
14:57:44 (INTEL) Unable to initialize access to trusted storage: 2
14:57:44 (INTEL) FlexNet Licensing version v11.11.1.1 build 119913 x64_lsb
14:58:09 (lmgrd) INTEL exited with status 0 signal = 17
14:58:09 (lmgrd) Since this is an unknown status, license server
14:58:09 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
14:58:09 (lmgrd) REStarted INTEL (internet tcp_port 53644 pid 20467)
14:58:09 (INTEL) Unable to initialize access to trusted storage: 2
14:58:09 (INTEL) FlexNet Licensing version v11.11.1.1 build 119913 x64_lsb
14:58:34 (lmgrd) INTEL exited with status 0 signal = 17
14:58:34 (lmgrd) Since this is an unknown status, license server
14:58:34 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
15:01:04 (lmgrd) REStarted INTEL (internet tcp_port 50944 pid 20572)
15:01:04 (INTEL) Unable to initialize access to trusted storage: 2
15:01:04 (INTEL) FlexNet Licensing version v11.11.1.1 build 119913 x64_lsb
15:01:26 (lmgrd) SHUTDOWN request from root at node pastec.gtri.gatech.edu
15:01:26 (lmgrd) lmgrd will now shut down all the vendor daemons
15:01:26 (lmgrd) Shutting down INTEL pid=20572 because of signal 15
15:01:29 (lmgrd) EXITING DUE TO SIGNAL 15
Unfortunately I don't know what questions to ask because I don't know what the problem is. Please advise
Feilong_H_Intel
Hi Ben,
Could you please email me your license file (/opt/intel/flexlm/server.lic)?  I'm sending my email via private message now.
Feilong_H_Intel
Ben,
Here are our findings.  According the table in this page (https://www.linuxbase.org/lsb-cert/productdir.php?by_lsb), SUSE 10 32-bit is complaint to LSB 3.0, while SUSE 10 64-bit isn't.  It appears that you will see "status code 17" error if you use 64-bit License Manager on 64-bit SUSE 10.  The solution is upgrade your OS or use 32-bit License Manager.
