I'm currently using F200 sensor with intel_rs_sdk_offline_package_r_3.1.0.85181 and I'm observing that it is extremly unstable. Attaching more devices to USB hub's causes it to stop responding after a moment from initialization, manager looses connectivity to it completly (sound of detached USB device) and it's process needs to be killed before next run. In other cases device is lagging with supporting frames.
My conclusion is that the current DevKit looks to be extremly power and bandwitch consuming. I need second sensor for proper stereoscopic reconstruction but I don't want to spend another 99$ if it will came out that SDK is not supporting that.
So is RealSense SDK supporting more than one F200 DevKit ?
The 4.0 (please upgrade) Gold R2 release of the RealSense SDK only supports one camera at a time.
Depending on your use case, you might look at the R200 camera that has RGB plus 2 lens for stereoscopic 3D.
Hmm, where I can order R200 devkit?
Or find more info about it?
Also, Is RS SDK supporting Creative RealSenz3D cameras ? And if yes, also only one or more?
You can get the dev kits from here:
https://software.intel.com/en-us/realsense/devkit
I think the current SDK only supports one camera.
The actual R200 order page is http://click.intel.com/realsense.html. Basic information on it is on the link samontab mentioned above.
I don't think there is a Creative RealSenz camera. The Creative Senz3D was for the 2013 PerC SDK and is not supported with the RealSense (2014/15) SDKs.
The Intel(R) Real Sense F200 camera has a Creative 800 number you can see at their FW/SW page on the Intel RealSense F200 camera http://support.creative.com/Products/ProductDetails.aspx?catID=218
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
