Software Archive
Read-only legacy content
17060 Discussions
Unable to add splash screens
Jeffrey_M_2
Hi, Team,  Am using intel XDK for building my app. Previously I use to add splash screens by using the launch icons and splash screen settings in the intel XDK. Now after upgrading to the latest xdk. Am unable to add splash images. Please advice how to add splash images.   Am using Cordova 4.1.2
John_H_Intel2
Can you post a screen cap of the issue you are seeing?
Anusha_M_Intel1
Are you not able to upload your images via the UI in the projects tab?
Jeffrey_M_2
Yes I tried adding images via the UI in projects tab. The screen shot is as follows.
John_H_Intel2
That is quite possibly the worst screen cap I have ever seen! My eyes went all buggy trying to look at it...Any way you can post a clear image?
Are you running the latest build of the XDK?
Are your images the correct format and size?
Anusha_M_Intel1
Yes, the screenshot could use some work. But I think your issue is that you are not even able to select your images for splashscreen. Am I right? In the meantime, there is an alternate way to do it using the additions file.
Take a look at this sample additions file for an example of how to do that: https://github.com/gomobile/sample-hello-cordova/blob/master/intelxdk.config.additions.xml
And then use the same method to add to your own intelxdk.config.additions.xml file.
Make sure you are using the latest XDK release, v2807 (look at the top right corner of your XDK). I will report this to engineering in the meantime.
