Software Archive
Read-only legacy content
17060 Discussions
Unable to debug without Crosswalk enabled
Brandt__Lars
Hi
It seems that there's a problem with a default setting on the cloud build server:
It stops the process diplaying this error:
If I go to build settings and enable "Optimize with Crosswalk" then the process will finish.
Thanks in advance
Lars B.
PaulF_IntelCorp
I'm guessing that you've added a Crosswalk version override in your intelxdk.config.additions.xml file, which is causing the problem (see the error message note). Remove that Crosswalk override and the build will work. One thing to be aware of, the Debug tab ALWAYS uses Crosswalk.
Brandt__Lars
No, there's nothing in the intelxdk.config.additions.xml file.
My problems all started with me being unable to add third party plugins. I therefore created a new project and copied my files from the old project. Then I was again able to add plugins. Just a thought, could there be something in files outside my project path causing it?
I did a search for "Crosswalk" in my project, and there nothing there with "18":
intelxdk.config.additions.xml------------------------------------------------------------------------------------------
 debuggable app for -->
<!-- Crosswalk apps on Android 4.0
ly affects Cordova builds for Crosswalk and Android. -->
intelxdk.config.android.app.xml------------------------------------------------------------------------------------------
rait"/></platform>
<intelxdk:crosswalk version="16"/>
<pr
intelxdk.config.crosswalk.app.xml------------------------------------------------------------------------------------------
on" value="auto"/>
<intelxdk:crosswalk version="15"/>
intelxdk.config.crosswalk.xml------------------------------------------------------------------------------------------
="xdk.intel.blank.ad.template.crosswalk" version="0.0.1" an
on" value="auto"/>
README.md------------------------------------------------------------------------------------------
ab)
-   in the App Preview Crosswalk container (Debug ta
Phone
-   Windows 8
-   Crosswalk
-   Chrome Deskt
Vinterman.xdk------------------------------------------------------------------------------------------
VersionCode_": "1",
        "crosswalkVersion_": "16"
Version_": "5.4.1",
        "crosswalkVersion_": "11",
Version_": "5.4.1",
\plugins\cordova-plugin-mauron85-background-geolocation\README.md------------------------------------------------------------------------------------------
 *google+*, *notifications*, *crosswalk* and *google maps*.
\www\xdk\init-dev.js------------------------------------------------------------------------------------------
tandard browser, App Preview, Crosswalk, etc.). It "unifies
PaulF_IntelCorp
That's very odd, because it is clearly indicating a CW 18 version for the debug build. I'll try to take a closer look on Friday, but I won't have much time and will be away on vacation thru Monday, so it may have to wait until Tuesday.
Are you able to build a custom debug module for the "hello cordova" sample app?
