Software Archive
Read-only legacy content
17061 Discussions
Unable to find older version of Parallel Studio XE Composer
DaleO
I just got a subscription for Intel® Parallel Studio XE Composer Edition for Linux.  I was able to register and download the latest version (2015).
I would like to be able to download the previous version (2013 I believe), but have been unable to figure out how.
Is it possible my subscription/license does not give me access to older versions?
I have looked at the page https://software.intel.com/en-us/articles/older-version-product. ; Following those instructions I do not see any older versions.
James_T_Intel
Hi Kirk,
Here is what you should see based on your licenses.  In your product list, you should find:
If you click on the version for any of these products, you should get the follow (showing C++):
Here, you should be able to select the appropriate version.  If you see something different, please provide a screenshot (either post with no identifying information or send to me in a private message).  Keep in mind that Composer Edition does not have a single download for the entire package.
DaleO
Thank you for your reply.
When I select a version I get "We are unable to find registrations/downloads matching this request".
I have attached a screen shot.
James_T_Intel
Does this occur with every component?
DaleO
For C++ and Fortran I get the 'unable to find registrations/downloads.."
For Parallel Studio XE Composer Edition and HD Graphics Drivers I get only the current versions.
For all others it shows older versions as well.
James_T_Intel
Please try again, we've made a change to the downloads.
DaleO
I now see older versions for all components.
Thank you!
falkenstern__alexand
same thing here. I try to download professional edition for Windows.
Regards.
James_T_Intel
Alexander,
Please send me a screenshot of what you are seeing in your product list.
Hello James,
screenshot is attached.
Thank you.
James_T_Intel
As I said in response to your private message, your support is expired.  You will only be able to download versions with a build date earlier than your support expiration.  You should be able to select an earlier version and download it.
That's right, the support is expired. I try to download Initial release of
Parallel Studio XE 2013, neither 2013SP1 nor 2015.
AFAIK, Initial release of XE 2013 was within our support timeline.
I'm not sure about XE 2013 Update 1.
Thank you.
