Software Archive
Read-only legacy content
17060 Discussions
Unable to receive Incoming calls (URGENT)
jaf8_00
Hi all,
Can any one help me in finding a solution for processing incoming calls ... Like Iam using the following
Iam using the AVDConf2 sample .. I've edited the registeration xml profile and have made it to register with Sip Express Router... I can make outgoing calls to any other sip compliant phone .. but I can't recieve any incoming calls...although Messaging is running both ways but I cant receive any incoming calls... Can any one help me out ...it would mean a lot to me
Thanx in advance
Junaid
Intel_Software_Netw1
Greetings from Intel Developer Services Support.
It looks like you're referring to our "Enriching Rich Client Communications with the Microsoft* Real-Time Communications API" piece: http://www.intel.com/cd/ids/developer/asmo-na/eng/microprocessors/ia32/pentium4/hyperthreading/43672.htm
We'll forward your question to the author and let you know what we find out.
Lexi S.
IntelSoftware NetworkSupport
Message Edited by intel.software.network.support on 11-30-2005 03:53 PM
Here is the response we received from the author:
The AVDConf2.exe was tested using Microsofts Voice Communication Server (or SIP Server) Beta 2. The protocol between the Beta and RTM should be the same. In the early testing of AVDConf2.exe, I noticed there was a difference in the return code and protocol scheme. A couple of things you will want to try when registering with a non-Microsoft SIP server:
  1. Test the SIP Server registration with AVDConf2.exe on both ends.
  2. Check the control packets to make sure the messages are what the application is expecting. If not, you may need to find out what messages the server is passing to the client.
I will also test this on Microsofts SIP server to make sure the protocols have not changed.
Lexi S.
We are curious to know whether the author's suggestions helped with your troubleshooting.
If we receive any further updates from the author, we will alsopost them here.
Lexi S.
Message Edited by intel.software.network.support on 11-30-2005 03:54 PM
