Software Archive
Read-only legacy content
17060 Discussions
Uncaught TypeError
Bart-Jan_v_
I keep running into
Uncaught TypeError: Cannot read property 'call' of undefined
which is caused by target-script-min.js:1283
I tried googling this error but couldn't find anything that made sense to me about this error. Can anyone explain what is going wrong here and how I can either fix or disable this error?
Thanks!
Roi_D_
Is target-script-min.js your script? could be from 3rd party library/plugin you are using. try to check you are using it correctly or if there is a newer version of the library/plugin you are trying to use?
Bart-Jan_v_
It seems to be generated whenever I use emulators in XDK, its not a 3rd party library/plugin or a script of my own.
PaulF_IntelCorp
That's an internal JS file, used by the Emulate tab, I believe. You can safely ignore it.
