Software Archive
Read-only legacy content
17060 Discussions
Will WebCL in crosswalk 17 + upgrade the app performance?
Shaul_H_
Hello, I read that in crosswalk 17 and above there is going to be a webcl option.  does this mean that applications will work better and much smoother?  it says that webcl gives the app the option to use the internal gpu... but i thought it is already an option in crosswalk, so i was wandering what is the difference and how can we use this to make our apps faster in future crosswalk versions?
Thanks for your time,
Shaul.
PaulF_IntelCorp
WebCL is an API that you can use from JavaScript to implement commands like those you would use in an OpenCL app. It is not a magic elixir that will make regular JS code faster. You have to explicitly write your app to use WebCL. It's a very specialized feature that tends to benefit multi-threaded parallel apps.
