Software Archive
Read-only legacy content
17060 Discussions
Unity 4.6.2 - build to x86_64 does not work
yosun
Innovator
I can't seem to get build to x86_64 to work - each time the build runs, the RealSense camera does not activate..
Does RealSense (current version) only work with x86? (Even though a x64 machine is required O_o)
Matthias_H_Intel
have you installed the drivers for the camera at all?
Iulian_D_
It works, make sure you add the 64bit version of libpxccpp2c.dll in the same folder with your application executable. For testing in the editor you have to use the win32 version of the library because Unity Editor is still on 32-bit architecture and can't load a 64bit version library.
Ricardo_Braga
I am using Unity 4.6.2. So far so good.
