Software Archive
Read-only legacy content
17060 Discussions
Update to intel xdk 3088 build failure issue
Jeremiah_D_
Hi. I’ve been having a persistent issue ever since I updated intel xdk to 3088.
I am building with android crosswalk 16.
I converted the legacy certificate to a new one as had been stipulated in the 3088 release notes.
But I'm still unable to guild my app. Kindly assist. Error log and snapshot are attached.
PaulF_IntelCorp
Jeremiah -- based on the second image, your project is trying to use the older versions of those plugins, which I am confident is the source of the failed build. Try the following:
  • remove the plugins using the Projects tab
  • switch your app to CLI 5.4.1 (with no plugins installed)
  • exit the XDK
  • in your project folder, remove the plugins directory
  • start the XDK
  • add the plugins back, using the Projects tab
When you are done, you should have a clean set of the new plugins.
PaulF_IntelCorp
The inappbrowser plugin is causing the problems. What version of the plugin are you using? Try changing your CLI to 5.4.1 and allow the XDK to also change your plugin versions at the same time. If you are using CLI 5.4.1, try changing to 5.1.1 and try the build again.
Jeremiah_D_
I tried the upgrade but it wasn't entirely successful. I get the following message on selecting the update CLI and plugin option.
I use the plugins below in my code.
And the build still fails.
PaulF_IntelCorp
  • exit the XDK
  • start the XDK
Jeremiah_D_
Thanks Paul. This solved the problem. I'm able to build successfully.
