Hi All,
after upgrade the version to 2496, i try to add cordova plugin (which they are used in my other project in previous version and working fine) into a new project and below is what i get by trying one by one
1. Facebook connect->unexpected call to process.exit()
->i am using a valid app id and app name in facebook registration
2. email_composer which the plugin id is de.appplant.cordova.plugin.email-composer
->took more than 5 minutes to run the fetching and non stop. so i have to kill it
3. custom intel xdk plugin: intel.xdk.device error
- Tags:
- HTML5
- Intel® XDK
Where are your project files located?
In XDK v2496 you have to put the project physically onto the same drive as XDK!
See this topic: https://software.intel.com/en-us/forums/intel-xdk/topic/594199#comment-1841270
Thanks Ad. Yes, my project is at different directory compare to where xdk installed.
@Khin -- we are working on an update to fix this issue.
on the same drive, okay but it is not really true.
tried to install XDK on E:, and installation fail at the end, but the program is lauching properly.
After that, always the same problem Process.exit when adding FB connect plugin for example.
Project is on the same drive E:
thanks for the update. looking forward the new update to fix it.
@Fab -- if you have the disk space I highly recommend that you let the XDK install in its "default" location.
