Software Archive
Read-only legacy content
17060 Discussions
Use openCV with Intel Realsense SDK
Deepak_k_
hi,
I want to do some image processing using depth and RGB stram of realsense camera. but i am not able to integrate opencv with realsense sdk. how can i receive depth frame in Mat variable of opencv so that i can do some processing in it.
thanks !!
Pubudu-Silva_Intel
RealSense SDK doesn't provide frames in mat format, but you can easily convert to mat
first you access frame data as follows
// image is a PXCImage instance
PXCImage::ImageData data;
image->AcquireAccess(PXCImage::ACCESS_READ,&data);
Note:  image planes are in data.planes[0-3] with pitch data.pitches[0-3]
Then you create an empty Mat using a constructor like this
Mat mat(int rows, int cols, int type)
after that you can copy data in to your  mat from data above.
finally release access to data
image->ReleaseAccess(&data);
Deepak_k_
how can i take video stream such as rgb, depth, ir in mat variable for processing.
thanks !!
Pubudu-Silva_Intel
Well the type of stream you get by the AquireAccess() is based on the type of PXCImage you called that method on :)
So if you want get RGB image frame, for example then you do the following
psm = PXCSenseManager::CreateInstance();
then for each frame you do
PXCCapture::Sample *sample = psm->QuerySample();
PXCImage *rgbImage = sample->color;
PXCImage::ImageData frmData;
rgbImage->AcquireAccess(PXCImage::ACCESS_READ, PXCIMAGE::PIXEL_FORMAT_NV12, &frmData);
then you create a mat and copy the data over from frmData. Once you no longer need frmData, you just release the access
rgbImage->ReleaseAccess(&frmData);
Hope this helps
samontab
Valued Contributor II
This is what I am currently using:
cv::Mat frameColor = cv::Mat::zeros(resolutionColor.height, resolutionColor.width, CV_8UC3);
cv::Mat frameDepth = cv::Mat::zeros(resolutionDepth.height, resolutionDepth.width, CV_32FC1);
cv::Mat frameIR = cv::Mat::zeros(resolutionIR.height, resolutionIR.width, CV_8UC1);
color stream:
PXCImage::PIXEL_FORMAT_RGB32, and then read the image as BGRA unsigned ints.
depth stream:
PXCImage::PIXEL_FORMAT_DEPTH_F32, and then read the image as floats.
IR stream:
PXCImage::PIXEL_FORMAT_Y8, and then read the image as unsigned chars.
Deepak_k_
this is what i am doing to get depth stream.
/* Creates an instance of the PXCSenseManager */
    PXCSenseManager *pp = PXCSenseManager::CreateInstance();
    if (!pp)
        wprintf_s(L"Unable to create the SenseManager\n");
        return 3;
    /* Collects command line arguments */
    UtilCmdLine cmdl(pp->QuerySession());
    if (!cmdl.Parse(L"-listio-nframes-sdname-csize-dsize-isize-file-record-noRender-mirror",argc,argv)) return 3;
    // Create stream renders
    UtilRender renderd(L"Depth");
    pxcStatus sts;
    do {
        /* Apply command line arguments */
        if (cmdl.m_dsize.size()>0)
            pp->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, cmdl.m_dsize.front().first.width, cmdl.m_dsize.front().first.height, (pxcF32)cmdl.m_dsize.front().second);
        /* Sets file recording or playback */
        PXCCaptureManager *cm=pp->QueryCaptureManager();
        cm->SetFileName(cmdl.m_recordedFile, cmdl.m_bRecord);
        if (cmdl.m_sdname) cm->FilterByDeviceInfo(cmdl.m_sdname,0,0);
        if (cmdl.m_csize.size()==0 && cmdl.m_dsize.size()==0 && cmdl.m_isize.size()==0)
            PXCVideoModule::DataDesc desc={};
            if (cm->QueryCapture())
                cm->QueryCapture()->QueryDeviceInfo(0, &desc.deviceInfo);
            } else
                desc.deviceInfo.streams = PXCCapture::STREAM_TYPE_DEPTH;
            pp->EnableStreams(&desc);
        /* Initializes the pipeline */
        sts = pp->Init();
        if (sts<PXC_STATUS_NO_ERROR) {
            wprintf_s(L"Failed to locate any video stream(s)\n");
            break;
        /* Stream Data */
        for (int nframes=0;nframes<cmdl.m_nframes;nframes++) {
            /* Waits until new frame is available and locks it for application processing */
            sts=pp->AcquireFrame(false);
                if (sts==PXC_STATUS_STREAM_CONFIG_CHANGED) {
                    cerr << "Stream configuration was changed, re-initilizing\n" << endl;
                    pp->Close();
                break;
            /* Render streams, unless -noRender is selected */
            if (cmdl.m_bNoRender == false)
                const PXCCapture::Sample *sample = pp->QuerySample();
                if (sample)
                    if (sample->depth && !renderd.RenderFrame(sample->depth)) break;
            /* Releases lock so pipeline can process next frame */
            pp->ReleaseFrame();
            if( _kbhit() ) { // Break loop
                int c = _getch() & 255;
                if( c == 27 || c == 'q' || c == 'Q') break; // ESC|q|Q for Exit
    } while (sts == PXC_STATUS_STREAM_CONFIG_CHANGED);
            cerr <<"Exiting..."<<endl;
now where should i add
in the code so that i can get depth stream in Mat frameDepth.
i am not able to get depth stream in Mat variable.
can you please provide me full source code where mat access any stream . I am stucked from last 10 days into same place.
please help me
thanks !!
Rémy_B_
Lesly_Z_
hey!
how do u get a good depth result with librealsense?
I am currently using this:
const uint16_t * depth_frame = reinterpret_cast<const uint16_t *>(dev->get_frame_data(rs::stream::depth));
cv::Mat depth16(360, 480, CV_16U, (void*)depth_frame);
cv::Mat depthM(depth16.size().height, depth16.size().width, CV_8UC1);
depth16.convertTo(depthM, CV_8UC1);
// min/max distance from the camera
unsigned short min = 0.5, max = 2.5;
cv::Mat img0 = cv::Mat::zeros(depthM.size().height, depthM.size().width, CV_8UC1);
cv::Mat depth_show;
double scale_ = 255.0 / (max-min);
depthM.convertTo(img0, CV_8UC1, scale_);
cv::applyColorMap(img0, depth_show, cv::COLORMAP_COOL);
cv::imshow("DEPTH", depth_show);
it returns a "depth image" from the video, but it is really noise with grains, not possible to see details of depth.
thanks
