Software Archive
Read-only legacy content
17060 Discussions
Using 3d segmentation and emotion detection together.
Peter_O_Hanlon
Innovator
Okay, so I have some code where I want to do both emotion detection and 3d segmentation together. I'm also doing gesture recognition. So, if I enable hand tracking and emotion detection, things work well. If I enable hand tracking and 3d segmentation, all works well. It's only when I attempt to mix and match emotion detection and 3d segmentation together that things go wrong. Specifically, when I call senseManager.init(handler), the code doesn't return from this call. Effectively, what I have is the following:
PXCMSenseManager senseManager = PXCMSenseManager.CreateInstance();
PXCMSenseManager.Handler handler = new PXCMSenseManager.Handler{ onModuleProcessedFrame = ProcessFrame };
senseManager.EnableHand();
senseManager.EnableEmotion();
senseManager.Enable3DSeg();
senseManager.Init(handler);
I'm curious, if anyone has been able to get these to work together.
Xusheng_L_Intel
This is known bug and will be fixed in future release. Currently you can not use emotion module with other module at the same time.
Peter_O_Hanlon
Innovator
Thanks David. Do you have any timescale on the fix?
Xusheng_L_Intel
You should get it pretty soon.
Piotr_P_
Is this bug fixed? I am using SDK version 2014, Gold, and observe problems with capturing gestures when emotions are enabled. Is there any patch to use emotions module and do not disturb others?
Tri
Has it been fixed? And could we use segmentation with gesture recognition at the same time?
