Software Archive
Read-only legacy content
17060 Discussions
Using Interrupts with Node.js on Galileo
Richard_B_1
Hi All After reading the announcement of the new XDK IoT development environment (IDE?) that uses node.js I have been trying to see what it can do. After a bit of refresher/learning about node.js/javascript (since only used a little with HTML a long time ago) I started to do some experiements. After a bit of a shock/learning curve at creating a program where each function runs in its own thread, so at the same time instead of in sequence as I am used to, I have gotten a motor controller board, sort of working. (PWM isn't working yet) The next thing I would like to try is to see if it is possible to use hardware interrupts to count wheel rotations (yes I know the timing isn't like an Arduino, but would like to see if can work.) So can anyone give me a hint on how to have a program written in node.js check for hardware interrupts? Thanks rgb
Raghavendr_U_Intel
Are you looking for something of this sort?
https://communities.intel.com/thread/47861
If this approach solves your issue, then you can use setInterval function in Node.js and call your handler.
Richard_B_1
Since this has been unanswered for a long time and I have seen the same question on another board, also unanswered, I guess that there isn't any way to do it. It seems might be possible under Python, but not node.js Whoever is moderating can delete this entry. thanks rgb
Raghavendr_U_Intel
