Software Archive
Read-only legacy content
告知
17060 ディスカッション
Using Pthreads on the Coprocessors
Anand_Pratap_S_
ビギナー
3,841件の閲覧回数
I wrote a simple advection equation solver using pthreads which works(and scales) correctly on the processor. However when I compile it using -mmic flag and run on coprocessor(using micnativeloadex), it uses just one thread(I am hard coding it to use 200). From what I know the code should work as it is. Am I missing something here?
The code is quite long and dirty, but still for completeness.
    #include <stdlib.h>
    #include <stdio.h>
    #include <pthread.h>
    #include <sys/time.h>
    #include <unistd.h>
    int64_t TimeInMicros() {
        struct timeval tv;
        gettimeofday(&tv, NULL);
        return tv.tv_sec*1000000 + tv.tv_usec;
    struct Grid{
      int nx;
      double *u, *u_new, *f, *res;
      double a, cfl, dx;
      double tf;
    struct ThreadData{
      int tid;
      struct Grid *grid;
      int maxthreads;
      pthread_barrier_t *barr;
    void *solver(void *args){
      struct ThreadData *td = (struct ThreadData *)args;
      int tid = td->tid;
      struct Grid *grid = td->grid;
      pthread_barrier_t *barr = td->barr;
      double *u = grid->u;
      double *u_new = grid->u_new;
      double cfl = grid->cfl;
      double a = grid->a;
      double dx = grid->dx;
      double tf = grid->tf;
      int nx = grid->nx;
      double *f = grid->f;
      double *res = grid->res;
      double dt = cfl*dx/a;
      double t = 0.0;
      int chunk = nx/(td->maxthreads);
      int start = tid*chunk;
      int rc;
      while(t < tf){
        // sync here
        if(start == 0){
        f[start+1:chunk] = a*u[start:chunk];
        else{
          f[start:chunk+1] = a*u[start-1:chunk+1];
        // sync here
        rc = pthread_barrier_wait(barr);
        if(rc != 0 && rc != PTHREAD_BARRIER_SERIAL_THREAD)
            printf("Could not wait on barrier\n");
            exit(-1);
        if(start == 0){
          f[start] = f[nx-1];
        res[start:chunk] = -(f[start+1:chunk] - f[start:chunk])/dx;
        // need to use update u_new for multiple threads
        u[start:chunk] += res[start:chunk]*dt;
            exit(-1);
        t+=dt;
      return NULL;
    int main(int argc, char*argv[]){
      int nx=100000;//atoi(argv[1]);
      int nthreads=200;//atoi(argv[2]);
      if(nx%nthreads != 0){
        printf("ERROR: Number of cells should be integral multiple of number of threads \n");
        exit(1);
      pthread_t *threads = new pthread_t[nthreads]();
      struct ThreadData td[nthreads];
      pthread_barrier_t barr;
      pthread_barrier_init(&barr, NULL, nthreads);
      double *u = new double[nx]();
      double *res = new double[nx]();
      double *f = new double[nx+1]();
      double dx = 1.0/nx;
      double cfl = 0.9;
      double a = 1.0;
      double tf = 1.0;
      int i;
      // initialize
      u[0:nx] = 0.0;
      u[nx/4:nx/2] = 1.0;
      f[0:nx+1] = 0.0;
      res[0:nx] = 0.0;
      struct Grid grid;
      grid.nx = nx;
      grid.a = a;
      grid.cfl = cfl;
      grid.dx = dx;
      grid.u = u;
      grid.u_new = u;
      grid.res = res;
      grid.f = f;
      grid.tf = tf;
      for(i=0;i<nthreads;i++){
        td.tid = i;
        td.grid = &grid;
        td.maxthreads = nthreads;
        td.barr = &barr;
      int64_t t1 = TimeInMicros();
        pthread_create(&threads,NULL,solver,&(td));
        pthread_join(threads,NULL);
      int64_t t2 = TimeInMicros();
      printf("Execution time: %.10f\n", (t2-t1)*1e-6);
      FILE * outfile;
      outfile = fopen("results.txt", "w+");
      for(i = 0; i < nx; i++){
        fprintf(outfile, "%.10f %.10f\n", i*dx, grid.u);
      fclose(outfile);
      delete[] threads;
      delete[] u;
      delete[] res;
      delete[] f;
0 件の賞賛
9 返答(返信)
James_C_Intel2
従業員
3,841件の閲覧回数
1) It may be worth checking the result of pthread_create
2) How do you know how many threads are being used? I see no code there that tells you (there are no printfs inside solver).
Kevin_D_Intel
従業員
3,841件の閲覧回数
I'm definitely not a pthread expert so hopefully others who are can chime in.
I ran your program on a system with MPSS 3.1 and it appears to be creating all the threads. After starting the executable using micnativeloadex, I connected to the card in another window and issued the commands shown below.
[root@mic0 ~]# ps H -C a.out | head
   PID TTY      STAT   TIME COMMAND
 65799 ?        Sl     0:00 /tmp/coi_procs/1/65799/a.out
 65799 ?        Sl     0:03 /tmp/coi_procs/1/65799/a.out
[root@mic0 ~]# ps H -C a.out | wc -l
203
Anand_Pratap_S_
ビギナー
3,842件の閲覧回数
My post mysteriously did not appear, posting it again.
Hi James and Kevin,
Thanks for the inputs.
It turns out I was making wrong interpretation. I was looking at the processor used using micsmc, which does not really change when I run the code. Putting print statements confirm that the threads are indeed created. However it spends so much time waiting at the barrier that it does not really use any processing power.
1. It worked perfectly on processor with the barrier function, I was expecting similar behaviour with coprocessor as well. Am I doing something wrong here? If i remove the barrier, it runs superfast however obviously it gives wrong results.
2. On a different note, I can easily vectorize every statement using array notation. In that case how do I run the executable using multiple threads? I cannot use cilk because there are no for loops.
Anand
jimdempseyatthecove
名誉コントリビューター III
3,841件の閲覧回数
What happens if you rewrite to use OpenMP? Your code is short enough to do this and it may shed some light on your issues.
Jim Dempsey
jimdempseyatthecove
名誉コントリビューター III
3,841件の閲覧回数
Untested code
#include <stdlib.h>
#include <stdio.h>
#include <omp.h>
#include <unistd.h>
    struct timeval tv;
struct Grid{
  int nx;
  double a, cfl, dx;
  double tf;
struct ThreadData{
  int tid;
  struct Grid *grid;
  int maxthreads;
  int tid = td->tid;
  double a = grid->a;
  int nx = grid->nx;
  double t = 0.0;
  int rc;
  while(t < tf){
    // sync here
    #pragma omp barrier
    if(start == 0){
    else{
    // sync here
    #pragma omp barrier
    if(start == 0){
      f[start] = f[nx-1];
    #pragma omp barrier
    t+=dt;
  return NULL;
    exit(1);
  double dx = 1.0/nx;
  double cfl = 0.9;
  double a = 1.0;
  double tf = 1.0;
  int i;
  // initialize
  u[0:nx] = 0.0;
  u[nx/4:nx/2] = 1.0;
  f[0:nx+1] = 0.0;
  res[0:nx] = 0.0;
  struct Grid grid;
  grid.nx = nx;
  grid.a = a;
  grid.cfl = cfl;
  grid.dx = dx;
  grid.u = u;
  grid.u_new = u;
  grid.res = res;
  grid.f = f;
  grid.tf = tf;
  #pragma omp parallel num_threads(nthreads)
    struct ThreadData td;
    td.tid = omp_get_thread_num();
    td.grid = &grid;
    td.maxthreads = omp_get_num_threads();
    if(nthreads != omp_get_num_threads()) {
      if(td.tid == 0) {
        exit(-1);
    else {
      solver(&td);
  FILE * outfile;
  fclose(outfile);
  delete[] threads;
  delete[] u;
  delete[] res;
  delete[] f;
Jim Dempsey
Anand_Pratap_S_
ビギナー
3,841件の閲覧回数
Hi Jim,
Thanks for the comments and code. This works correctly. Any idea why the pthread code was not working?
Anand
TaylorIoTKidd
新規コントリビューター I
3,841件の閲覧回数
Anand,
Looking at the code, you also posted this on Stackoverflow. I'm not going to post anything there so you can have input from two different communities.
Please post any solution you get from stackoverflow to these forums, and this forum to stack overflow. It'll help the broader community of users.
Thanks!
Taylor
jimdempseyatthecove
名誉コントリビューター III
3,841件の閲覧回数
The function solver is essentially the same, although I added the barriers where your comments indicated a barrier ought to be.
Note, the first barrier I used (where your comment indicated) is (may be) superfluous.
If I were to guess I would think something is wrong (different) with the pthread barrier. Are you using the .so compiled for MIC? It can be problematic using a host version of libraries with requirements specific to an instruction set. There are some minor differences that may be problematic (perhaps PAUSE verses DELAY32/DELAY64).
Jim Dempsey
jimdempseyatthecove
名誉コントリビューター III
3,841件の閲覧回数
Anand,
From the little experience I've had with Xeon Phi is when you have 244 threads, barriers are expensive. You should do what you can to work around the barriers. A good example of how you can do this can be found in one of my blog articles on IDZ. The relates to a plesiochronous phasing barrier (loosely-synchronous).
I haven't performed a time-domain analysis of your code, but it appears that it may be capable of incorporating the plesiochronous phasing barrier. What this means in a nutshell is any given thread is only dependent upon one neighboring thread with the exception of the thread with start == 0 which is dependent upon two threads (tid+1 and last tid).
To implement, the main (caller) would initialize the ThreadData objects to include a pointer to a progress array: an array of volatile int's of size == to number of threads. Prior launching the thread team, the array is initialized to 0's. Then as each thread reaches a milestone (completes a section of code) it then increments its progress pointer (++td->progressArray[tid]). Then where your barrier is required, it can consult the appropriate neighboring progress array entry (to right or left or last) as the case may be. In the article I used a conditional compile statement to define a macro to wait a short time. Host uses _mm_pause(), MIC uses _delay32(nnn).
This strategy may work well for you too. A suggestion though is seeing how the first thread (tid==0) waits for last thread, consider giving it more work to do (IOW make its chunk larger).
Before you implement this, look at the time domain dependencies. If they all run in one direction you may experience significant speed-up. If the time domain dependencies run both ways then all is not lost. The technique to employ there is to partition the work (one CEAN statement) into two statements. One is a short stub containing the last vector's worth of data at the tail-end of the region of work which is executed first, then increment progress variable, then perform bulk of remainder of front-end. This way, the dependent thread can resume early while the other threads completes its work.
Jim Dempsey
返信
