HI,
I want to use the Real Sense Speech Command functionality throw web services. Client application will communicate through audio files.
Is it feasible to use the Real Sense in this way?
Thank You,
链接已复制
4 回复数
I don't know what the answer is, but it did remind me of a discussion I had on this forum the other day where I suggested the possibility of processing the camera's DLL library files online in the cloud instead of locally on the computer and then sending the results of the processing down to the computer. Videogame streaming services that use this method transmit the processed signal to and from the computer as a video signal. Maybe you could investigate doing something similar.
