Software Archive
Read-only legacy content
17060 Discussions
Using evaluation DLLs
Deleted_U_Intel
I am new to the list, and spell check showed my post all jumbled up.
If that is how it will come across, I apologize
I'm trying to use a DLL for evaluation purposes.
Here is what the authors suggested I should use for VB:
DataToEncode = InputString.Text
'Format the Output by calling the DLL
'Make sure to add the COM Server DLL to the references!!
Dim DMFontEncoder As DMATRIXLib.Datamatrix
Set DMFontEncoder = New Datamatrix
DMFontEncoder.FontEncode DataToEncode, 0, 0, 0, Printable_string
'Printable_string contains the data formatted for the font
PrintableBarcodeString = Printable_string
This is the encoder DLL that formats the Data Matrix font. It can be found in the system directory after installation. Because it was created with C++ using ATL, it is small and has no dependencies.
How can I use it w/cvf?
Here is what I tried following a sample from the cvf's CD:
Program Test_2d_Barcode
use kernel32
INTERFACE
SUBROUTINE rtn_FontEncode(STR_IN,I_TILDE,I_MODE,I_PREF,STR_OUT)
CHARACTER STR_IN*25,STR_OUT*100
INTEGER*2 I_TILDE,I_MODE,I_PREF
END SUBROUTINE
END INTERFACE
CHARACTER BARCODE_IN*25,BARCODE_OUT*100
POINTER (p,i)
POINTER (q,rtn_FontEncode)
BARCODE_IN = '1234512340123456789801010'
p = loadlibrary("IDAutomationDMATRIX.DLL"C)
Q = getprocaddress(p, "dllgetclassobject"C)
CALL rtn_FontEncode(barcode_in,0,0,0,barcode_out)
WRITE(*,10) BARCODE_OUT(1:25)
10 FORMAT(A,/,25(Z2,1X))
END
I get a forrtl severe (157)
p returns a non-zero, whereas q returns a zero.
I have never coded anything that uses dlls written by someone else.
My son was able to get the VB code to work!!
Help please.
tia
Intel_C_Intel
I suggest reading the Using COM and Automation Objects chapter of the CVF Programmer's Guide. That should get you started.
hth,
JT
