Just converted at app to V3088
Finally got the certificates updated.iOS build fine but the Android build fails. This is the error towards the end of the log.
symbol: class CordovaChromeClient
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1184: error: cannot find symbol
CordovaChromeClient ccc = new CordovaChromeClient((CordovaInterface) activity, remoteView);;
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1191: error: incompatible types: CordovaWebView cannot be converted to View
remoteLayout.addView(remoteView);
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1202: error: cannot find symbol
remoteView.requestFocus(View.FOCUS_DOWN);
symbol: method requestFocus(int)
.../WFSL/platforms/android/src/com/intel/xdk/device/Device.java:1203: error: cannot find symbol
remoteView.setOnTouchListener(new View.OnTouchListener() {
symbol: method setOnTouchListener(<anonymous OnTouchListener>)
Note: .../WFSL/platforms/android/src/com/intel/xdk/device/Device.java uses or overrides a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: .../WFSL/platforms/android/src/com/intel/xdk/device/Device.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
Note: Some messages have been simplified; recompile with -Xdiags:verbose to get full output
16 errors
FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':compileArmv7ReleaseJava'.
> Compilation failed; see the compiler error output for details.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 22.303 secs
.../WFSL/platforms/android/cordova/node_modules/q/q.js:126
throw e;
Error code 1 for command: .../WFSL/platforms/android/gradlew with args: cdvBuildRelease,-b,.../WFSL/platforms/android/build.gradle,--no-daemon
Command finished with error code 1: .../WFSL/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../WFSL/platforms/android/cordova/build: Command failed with exit code 1
You may not have the required environment or OS to build this project
at ChildProcess.whenDone (.../cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
at emitTwo (events.js:87:13)
at ChildProcess.emit (events.js:172:7)
at maybeClose (internal/child_process.js:821:16)
at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
- Tags:
- HTML5
- Intel® XDK
After updating to CLI 5.4.1 the build was successful.
