Software Archive
Read-only legacy content
V3400 clicking button during design causes framework error
Nick_F_2
New Contributor III
If I click a button in design using App Framework 3 I get an error dialog saying For Security Reasons, Framing is not Allowed. When I click OK I get a GitHub webpage load over XDK, The definitive HTML5 mobile javascript Framework.
There is no way to return to XDK, and XDK will not quit from the menu, I have to Force quit and restart XDK.
Nick_F_2
New Contributor III
I have attached a screen video of the error occurring. I cannot edit my existing post I'm getting Access Denied.
Mohammed_A_1
Thank you for rising this issue. I have same issue and looking for help. I don't know what i did wrong since i have only 2 days using XDK.
Thanks again
Navix_S_
I have the same issue using Mac OS X version. I'm new and just using prepared template following the tutorial, don't think of any significant mistake I made...?
Nick_F_2
New Contributor III
This is a nightmare, its happening now when dragging controls onto designer.
I cannot work with this, it is a major problem.
Mohammed_A_1
Guys,
I changed the framework as the following and there is no issue. I think problem is with the App Framework V3.
Hope some one to answer us :)
Swati_S_Intel1
Thanks for bringing this up. I was able to reproduce this with App Framework. I've escalated the issue to the AF engineers.
Sacher_d_
The same issue exists on Windows 10 platform.  The same issue exists for my other team members as well.
We use App Framework 3 for a project.  Just placed a header into the design and clicked on that.  After a second a popup comes up saying "For security reasons, framing is not allowed".  After clicking OK, the application shows github page and there is no way to go back to my design activity, other than to kill the app and restart.
Too much of a trouble.
Ariska_Hidayat
Hi Guys,
Solution for the moment, you can replace it with another framework when creating a new project. You can still use 3 framework cool.
PaulF_IntelCorp
BTW -- we have deprecated App Framework as a UI framework for App Designer, and will be discontinuing support for it in future releases of the XDK. See this FAQ for details > https://software.intel.com/en-us/xdk/faqs/app-designer#best-app-designer-framework <
Mohammed_A_1
Paul F. (Intel) wrote:
BTW -- we have deprecated App Framework as a UI framework for App Designer, and will be discontinuing support for it in future releases of the XDK. See this FAQ for details > https://software.intel.com/en-us/xdk/faqs/app-designer#best-app-designer... <
something strange happened again. when i am trying to create  a new project usually it give me option to select which framework i am going to use " the last step". right now i can't i just select the name of project and the path then it automatically select App Framework 3 ?
can you help ? and can I downgrade my version to previous version ?
thanks.
Nick_F_2
New Contributor III
Me too, I have been testing and found that about every 4th or 5th attempt at creating a project I might get the option to select a framework otherwise I'm stuck with App Framework 3
PaulF_IntelCorp
There is a weird bug in the XDK that forces you to the same UI framework if you use the same project name for a new project. See this post and the following posts > https://software.intel.com/en-us/forums/intel-xdk/topic/624082#comment-1867741 < for a solution to the problem.
Nick_F_2
New Contributor III
Hi Paul
Yes I have had this issue before, but these are new projects with different names. Each project I created to test this had a different name to ensure I wasn't getting the same issue as before, but as said in the original thread it can be 4 or 5 new projects before I get prompted for the framework. They default to AF 3.
Swati_S_Intel1
 Nick, please send your global-settings.xdk file from this folder ~/Library/Application Support/XDK/ .
Chris_P_Intel
The App Framework docs are redirecting to GitHub, which is hijacking the documentation iframe. I'll see about getting this corrected.
Nick_F_2
New Contributor III
Hi Swati S,
I have sent you a PM with my global-settings.xdk file attached.
Andrea_O_
Sorry, i've the same problem on both my OS, Ubuntu 14.04 LTS and Windows 10.
So what i've to do? i've to change from Framework V3 to an other settings? Or i can change something and continue to work on my current project?
PaulF_IntelCorp
Andrea -- there are multiple issues being discussed in this thread, so I'm not clear on what you are referring to, but I suspect you may need the workaround described here > https://software.intel.com/en-us/forums/intel-xdk/topic/659434.
If that is not the issue you are referring to, please start a new thread with the appropriate subject. I'm closing this thread due to the confusing array of issues.
