Software Archive
Read-only legacy content
17060 Discussions
VTune 2015 Trial Version License Error
S_D_
I downloaded and installed a 30-day trial version of Intel VTune Amplifier XE 2015 today on my windows 64-bit machine. However, after running some profiling, as part of opening the results, VTune is throwing a license check error, similar to below.
License Check Failed
Intel VTune Amplifier XE 2015 cannot find a license file. Data cannot be displayed.
Error 0x4000001f (No valid license) -- License file is not found. Make sure that your license file is in the correct location and readable.
In the About VTune dialog > Details tab, the "License Type" and "Expiration Date" fields are empty.
What do I need to do fix this issue so that I can view the profiled results?
thanks!
Light_Intel
We now have a workaround for this issue. Please see the following article:
https://software.intel.com/en-us/articles/Intel-VTune-Amplifier-Evaluation-Version-License-Error
Also bear in mind. An evaluation license is only good for 30 days. Once it had expired it will no longer be usable.
Trishla_S_
Thank-You so much Sir.
Trishla_S_
Hello Mr.Anderson
I couldn't find the eval license file in my registered e-mail id.
Can you please send me the file to trishla.it@gmail.com
Thank-You Sir
Trishla
Trishla_S_
Hello Sir,
I followed the instructions on the page and got the license file.
Thank-You Sir
eddie_c_
I am getting the same issue, could you send me the license file?
eddie.christian@digitalsignalcorp.com
Hubert_H_Intel
Hi Eddie,
License file sent.
Regards, Hubert.
Dixit_P_
I'm also getting the same issue of missing license file, while attempting to use this trial version. Could you send me the license file. Thanks in advance.
Josie_Y_
I am also getting the same issue, could you please send me the license file as well? Thanks!
josie.yang@cloudgine.com
Hubert_H_Intel
Hi Josie,
I've sent the license file to your email address.
Regards, Hubert.
Josie_Y_
Hey Hubert, that was fast! Thank you very much!
Dixit_P_
Hello Hubert, I'm also getting the same issue of missing license file while attempting to use this trial version. Could you send me the license file. Thanks!
Dixit.Patel@emc.com
Hubert_H_Intel
License file sent. Hubert
Vlad_S_1
Hello Sir,
I have the same issue with the license. Could you kindly send me the license file? vlad.spiridonescu@gmail.com
Kind regards,
Vlad
Alex_D_1
Same issue again.  Please send the license to my email.  Thanks in advance!
Bodnar_T_
Hello Hubert!
Could You send me the licence file?
Thanks!
Tamas
Hubert_H_Intel
Tamas,
Under which email did you registered your eval license?
Hubert.
Bodnar_T_
bodnart@cadline.hu
Hubert_H_Intel
License file sent. Hubert.
Anton_I_
Hello Hubert! Could yo send me the EVAL license as well. Thanks!
Anton sabr744b@gmail.com
liufei_w_
  hi ,
   wenliufei@sohu.com
Xavier_F_
Same issue here as well, I tried to request the licence via my user account but I did not figure out how. Could you send me the licence file ?
Best,
Xavier
Hubert_H_Intel
Xavier,
Which is your email you used for registration? Please answer via "Send Author A Message".
Regards, Hubert.
