Software Archive
Read-only legacy content
VTune 9.1 Evaluation - Invalid License
Tommy_L_
I am trying to evaluate VTune 9.1, but the serial number doesn't work.  I obtained the serial number through Intel's license management page and entered it during the installation.  I am installing on Ubuntu 9.10, but get the "Invalid license" error, so could not proceed with installation.  Could you please help?
Thank you,
Tommy
Yuan_C_Intel
Hi, Tommy
Vtune 9.1 is a quite old version product.
Please try below link to get an evaluation license for newer version Vtune, which named as Intel(R) Vtune Amplifier XE:
https://registrationcenter.intel.com/RegCenter/AutoGen.aspx?ProductID=1810&AccountID=&EmailID=&ProgramID=&RequestDt=&rm=EVAL&lang=&pass=yes
You will receive the license through your registered email. This license should also work with old version product.
Hope this helps.
Tommy_L_
Hi Yolanda,
Thank you for the response.  Yes, it is old version, but I need old version of VTune so that it would work with our Ubuntu server running version 9.10.  As I understand, newer version of VTune does not support Ubuntu 9.10.  I did signup for newer version of VTune to get a serial number, but the key doesn't seem to work with VTune 9.1.
Yuan_C_Intel
Hi, Tommy
Have you tried install latest Vtune on Ubuntu 9.10? Have you met any errors?
Although it's not officially supported, we sometimes can work-around the problem on the old platform.
Thank you
