Software Archive
Read-only legacy content
17060 Discussions
Vertex Shader Info Please!
sjmx
Hello im just trying to find out if the vertex shader can be changed or updated on the Mobile Intel 945GM/GU Express Chipset Family as i've brought a new game which requires atleast 1.1 and this is 0.0.
Any sort of help or info would be much appreciated and if i can make it atleast 1.1 so i can play this game without it crashing after playing for a little while.
Thanks Steve
sjmx
Please can someone help me because ive asked lots of people and the only people that are going to know this question are intel users there self or intel.
tormentorduo
945 chipsets got only Software Vertex/pixel shaders but 965 are supposed to have Hardware shaders
tonymayall
I also have the same problem. Its very annoying as I have spent 550 on this laptop just a few months agoand found Tiberium wars does not run on it because of this. Is there no hope then?? Is it worth petitioning EA for a patch maybe? Would that be possible? I am seriously annoyed.
chroncile
Actually they have Hardware pixel shaders, but software Vertex shaders.
sjmx
Im not much of a computer expert so may i ask if it does not have vertex hardware but it has vertex software will it run Cnc3 Tiberian Wars & how do i get the vertex software and would it run the game with the correct software?
Thanks SjmX
tonymayall
From the replies we have had, it seems like it is not looking good. From whats been said, it would seem that the software emulation is present, but the game does not like it and requires the hardware. Looks like we have no other option than to sell our laptops and buy ones with the required hardare support. Its annoying because my desktop, which is nearly half the spec of my laptop, runs it fine, even though it does not meet the minimum requirements in a few areas!
m1stersax0n
Ok.... Listen up peeps before u trash ur loverly laptops, heres what I know.
Command and Conquer 3 Tiberiam Wars works fine with the Intel 945 GM chipset.
In C&C3 settings just set ur shaders to medium, everything else as low as possible or just low. 1024 x 768 will work better than 800x 600, dont ask me why, it just does. I have just 128 graphics memory and 512k main memory, It works fine. I have INTEL centrino duo Packard Bell Easynote MV laptop, Running XP Home.
Big Love all,
Johnny.
agent_j
chroncile:
That's only true for the Q963/965. The G965 has both hardware pixel and vertex shaders (as well as hardware T&L)
tonymayall
You are an absolute GENIUS!!!! How did you find out this info ( maybe I should not question manna from the gods). Many thanks dude, you are my saviour!!
justforyou_com
Hi all, i've recently brougha game called Joint Task Force and it requires me to have a 1.1 Vertex Shader however i only have 0.0 Vertex Shaders at the moment. i would use the response from before, but the game cant even open because of these requirments.
Would appreciate it if anyone could help me out here?!
mikestenger
Quoting - m1stersax0n
Big Love all,
Johnny.
Nice man, that helps a lot. My pc isn't too great either but now it's working just fine!
Awesome!
Latest Online Lead Generation Strategies
