Software Archive
Read-only legacy content
17060 Discussions
Visual studio installation is required or not to work with Intel parallel studio
Senthil_m_
Does prior installation of visual studio is required for  working with Intel parallel studio XE2013 ? .
or Intel parallel studio and all its feature works with out Visual studio Installation?
SergeyKostrov
Valued Contributor II
>>Does prior installation of visual studio is required for working with Intel parallel studio XE2013 ? . >> >>or Intel parallel studio and all its feature works with out Visual studio Installation? Intel Software Development tools are always intergrated with MS Visual Studios and take a look at installation requirements for more details on supported versions of Visual Studios.
Kirill_R_Intel
No, this is not correct. There is no requirement to have Visual Studio installed, it is optional. The tools in Intel(R) Parallel Studio XE have standalone GUI: Intel(R) ​VTune(TM) Amplifier XE, Intel(R) Inspector XE, Intel(R) Advisor XE. You can use them fully-functional without MS VS.
Compiler doesn't have its own GUI, but is available from command line without Visual Studio.
Kirill_R_Intel
Correction: Intel(R) Composer XE is not fully independent from MS VS, you'll need at least MS VS Express edition or Windows SDK. This depends on your configuration, check the release notes:
http://software.intel.com/en-us/articles/intel-c-composer-xe-2013-sp1-release-notes
Bernard
 VTune and the rest of Intel profiling/monitoring tools can be used as a standalone programs.
The only component of Intel Parallel Studio XE that requires prior installation of Microsoft Visual Studio is Intel C++ Composer XE. All of the other tools will work with the Visual Studio 2010 Shell environment provided by Intel Visual Fortran and they also have their own independent GUI.
