Software Archive
Read-only legacy content
17060 Discussions
Wanted example SQL data driven project
alan_b_4
HI Guys
Please excuse me if this has been covered, I couldn't find it.  I'm new to XDK and I'm looking to build an SQL data driven app for Android / IOS.
Do
any of you have any examples or tutorials that cover these areas
  • Connecting to an SQL database (cloud hosted SSL certificate based  server)
  • Logging on (user name and password stored in SQL)
  • Pushing data back to the SQL server database
  • Retrieving data from the SQL server database
I have a reasonably good grasp of retrieving record sets in Java using Rest and I'm Ok with SQL queries, not so good with connection strings and a day 1 user with the XDK.
To speed things up, I'm willing to pay a nominal donation if someone can put a template together for that I can work from.
Many Thanks
Al
PaulF_IntelCorp
I recommend you explore the general HTML5 programming sites on the web (such as W3C Schools, StackOverflow and HTML5 Rocks). We are only staffed to provide you with Cordova/XDK-specific issues, we don't have the resources to answer general HTML5 questions.
alan_b_4
Thanks Paul,  At least now I have a starting place of where to look :)
Al
Dan_K_
Alan,
I struggled with this same problem. Turns out both HTML5 and Javascript cannot talk directly with an SQL database (who knew? I didn't). Anyway, PHP is the language of choice to talk with SQL.
Here are the steps to use a MySQL database with XDK.
1) create your database on a server.
2) write the php code that talks with the MySQL DB and put it on the same server where you created the database.
3) add a Javascript function to you HTML code to access the database and return data.
Here's a sample php file, apiDB.php followed by the Javascript function. When the data is returned, I save it localStorage.
BTW, I'm not a php or javascript expert. I actually had this code written by someone off shore.
PHP code to access MySQL
<?php
    error_reporting(E_ALL);
    ini_set('display_errors', 1);
    header("Access-Control-Allow-Origin: *");
    $username = "myUser";
    $password = "User$db";
    $hostname = "localhost";
    // Create connection
    $con=mysqli_connect($hostname,$username,$password);
    // Check connection
    if (mysqli_connect_errno()) {
      echo "Failed to connect to MySQL: " . mysqli_connect_error();
      die();
    //create database dgkwebco_AXIsql if not exists
    $sql_1 = "CREATE DATABASE IF NOT EXISTS mySQL";
    if (mysqli_query($con,$sql_1))
    else
      echo "Error creating database: " . mysqli_error($con);
      die();
    //select the database for further operations.
    $sql_2 = "USE mySQL";
    if(mysqli_query($con, $sql_2))
    else
        echo "Error selcting database mySQL: " . mysqli_error($con);
        die();
    $sql_3 = "CREATE TABLE IF NOT EXISTS customers (
            customerName varchar(23) DEFAULT NULL,
            customerCode varchar(13) DEFAULT NULL,
            emergencyPhone varchar(13) DEFAULT NULL,
    if(mysqli_query($con, $sql_3))
    else
        echo "Error creating table customers: " . mysqli_errno($con);
        die();
    if(isset($_GET["findCustomerCode"]))
        $code = $con->real_escape_string($_GET["findCustomerCode"]);
        $sql_8 = "SELECT * FROM customers WHERE customerCode='$code'";
        $result_1 = mysqli_query($con, $sql_8);
        if($result_1->num_rows > 0)
            echo json_encode(mysqli_fetch_array($result_1));
        else
            echo "false";
javascript code to get data from MySQL
<script>
// this function is called when a button is clicked. The user enters a code and clicks an "agree" button
function agree_clicked()
            var customerCode = document.getElementById("input-field").value;
            if(customerCode == "")
                alert("Please enter a customerCode");
            var url = "http://myServer.com/apiDB.php?find_customer_code=" + encodeURIComponent(customerCode);
            var request;
            if(window.XMLHttpRequest)
              request = new XMLHttpRequest();
            else if(window.ActiveXObject)
              try
                request = new ActiveXObject('Msxml2.XMLHTTP');
              catch (e)
                try
                  request = new ActiveXObject('Microsoft.XMLHTTP');
                catch (e) {}
            request.open('GET', url);
            request.onreadystatechange = function() {
              if(request.readyState === 4)
                if(request.status === 200)
                    if(request.responseText == "false")
                        alert("Please enter a valid password");
                    else
                        var obj = JSON.parse(request.responseText);
                        localStorage.setItem("customerName", obj.customerName);
                        localStorage.setItem("customerCode", obj.customerCode);
                        localStorage.setItem("emergencyPhone", obj.emergencyPhone);
            request.send(null);
    </script>
