Software Archive
Read-only legacy content
17060 Discussions
Web Server IPs messed up
Not applicable
I haven't done anything special to the original WebServer sketch and in serial when the sketch is run  I get the following, any ideas anyone please.
server is at 255.255.255.255
subnet mask 255.255.255.255
gateway IP 255.255.255.255
dns server IP 255.255.255.255
Jayesh_K
Hi AdamMiltonBarker,
   I am assuming that this is Galileo board. Please correct if I am wrong here.
In Galileo's case please check if the firmware version is smaller than 0x1000000, you need to update firmware.
File to check for firmware version:  /sys/firmware/board_data/flash_version
Please refer to the Galileo Getting Started Guide for instructions on how to update it (Step 4: Update Firmware).
Hope it helps.
Not applicable
Hi yes sorry it is the galileo. I did the firmware update after the problem happened and also again since I got the Grove iot kit so I don't think it is that but will check the version and try again and get back to you thanks for replying.
Not applicable
No this wasnt the issue, I did need to update to 1.0.2 but the problem is still the same when running the WebServer sketch on the Arduino IDE ( Windows8) I get:
Then nothing else.
Jayesh_K
   Could you please follow steps mentioned in https://communities.intel.com/message/236907#236907 and post your result here?
Not applicable
Hi thanks again for the reply no, no change, I have no issues with connecting to the internet though, the modified WebClient sketch I made works fine and connects successfully it is only the WebServer that I am having issues with. Same response in serial again:
Not applicable
Have moved over to node.js using Notedpad and WinSCP, server works fine, making progress now.
Matthias_H_Intel
if on Node.JS you might also consider using the Intel XDK for IoT https://software.intel.com/en-us/html5/xdk-iot rather using Notepad
Not applicable
Hi thanks but I also had issues with the XDK https://software.intel.com/en-us/forums/topic/541939 as well. For now I am sticking with notepad it works lol.
