Software Archive
Read-only legacy content
17060 Discussions
Weird Fortran crash
Intel_C_Intel
This is the line that crashes when I run the code in debug mode:
HMX = HMX*HMX2SM
Here is the context of the Fortran line above:
SUBROUTINE IOCBCO2SM(T, P, HMX, DHMX)
! DESCRIPTION OF VARIABLES
! T: TEMPERATURE
! P: PRESSURE
! HMX: MOLAR ENTHALPY
! DHMX: MOLAR HEAT CAPACITY
! DECLARING VARIABLES
DOUBLE PRECISION T, P, HMX, DHMX
! INCLUDING IO DATA CONVERSION PARAMETERS
INCLUDE 'IOPARAM.FOR'
! CONVERTING DATA DEPENDING ON MODEL
T = T*TA2SM + TB2SM
P = P*P2SM
HMX = HMX*HMX2SM
DHMX = DHMX*DHMX2SM
! RETURN TO INTERFACE ROUTINE
RETURN
END
File IOPARAM.FOR looks as follows (I have removed some lines):
! DECLARING PARAMETERS
! CO UNIT: mol/s, SM UNIT: mol/s
DOUBLE PRECISION, PARAMETER :: NF2SM = 1D0
! CO UNIT: Pa, SM UNIT: Pa
DOUBLE PRECISION, PARAMETER :: P2SM = 1D0
! CO UNIT: K, SM UNIT: K
DOUBLE PRECISION, PARAMETER :: TA2SM = 1D0, TB2SM = 0.0
! DATA FOR CONVERSION BETWEEN SIMULATION MANAGER AND CAPE-OPEN FOR CALL-BACK TO
! THERMODYNAMIC ROUTINES.
! CO UNIT: J/mol, SM UNIT: J/MOL
DOUBLE PRECISION, PARAMETER :: HMX2SM = 1D0
! CO UNIT: J/(mol*K), SM UNIT: J/(mol*K)
DOUBLE PRECISION, PARAMETER :: DHMX2SM = 1D0
!**** END OF FILE: IOPARAM.FOR ***
Why does this particular line crash? Why not the line above it?? Or the line below it??
-Bernt
isn-removed200637
It will be easier to offer help if you first post code using HTML tags as follows:
code here
Replace [] with <> to get it to work. I have used []
because I am not posting code. HTH
Jugoslav_Dujic
Valued Contributor II
Take a look at the calling code. I bet that the actual 3rd argument (HMX) is a constant (literal or parameter). You mustn't do that -- you were trying to modify the value of the constant, which is a no-no. You have to make a temporary either in caler or in the callee. Luckily, CVF 6.x does raise an access violation on these -- what a coincidence, I've just been debugging such lint on 5.0D which didn't cause a run-time error, but, far worse run-time misbehaviour.
Jugoslav
Intel_C_Intel
SUBROUTINE IOCBCO2SM(HMX)
DOUBLE PRECISION HMX
DOUBLE PRECISION, PARAMETER :: HMX2STD = 1
HMX = HMX*HMX2SM
RETURN
END SUBROUTINE
As is seen, HMX is not a constant/a parameter.
However, I call the subroutine like this:
CALL IOCBCO2SM(1D0)
Queston: Does this *effectively* make the argument a constant?
-Bernt
Jugoslav_Dujic
Yes, 100 is a constant (it is literal (unnamed) constant as opposed to parameter, which is a named constant). You mustn't modify 100. Approximately, this "100" compiler translates as an entry in a table physically located in .exe, which is loaded into memory when executed. Since Windows doesn't allow self-modifying programs, it protects this piece of memory from writing; thus the crash.
Intel_C_Intel
Actually, Windows does allow self-modifying programs and CVF even creates them. Here is a disassembly of the code for subroutine set_params in my first post to the thread "two interfaces for the same routine?" in comp.lang.fortran:
_COMPUTE_MOD_mp_SET_PARAMS@16 PROC
	push	ebp
	mov	ebp, esp
	sub	esp, 32
	lea	ecx, dword ptr _FUN$0002@4										   ; 000030
	mov	eax, dword ptr 8[ebp]											   ; 000006
	mov	edx, dword ptr 12[ebp]
	mov	dword ptr -15[ebp], ecx											   ; 000030
	mov	dword ptr -10[ebp], ebp
	fld	qword ptr [eax]												   ; 000028
	mov	byte ptr -16[ebp], 185											   ; 000030
	fstp	qword ptr -24[ebp]											   ; 000028
	mov	byte ptr -11[ebp], 184											   ; 000030
	fld	qword ptr [edx]												   ; 000029
	lea	edx, dword ptr -16[ebp]											   ; 000030
	fstp	qword ptr -32[ebp]											   ; 000029
	mov	word ptr -6[ebp], 57855											   ; 000030
	push	edx
	push	dword ptr 16[ebp]
	call	dword ptr 20[ebp]
 ;     38       end subroutine set_params
	mov	esp, ebp												   ; 000038
	pop	ebp
	ret	16
_COMPUTE_MOD_mp_SET_PARAMS@16 ENDP
Careful analysis reveals that it creates the code sequence:
mov ecx, {address of _FUN$0002@4}
mov eax, {stack frame pointer of _COMPUTE_MOD_mp_SET_PARAMS@16}
jmp ecx
at [ebp-16] and then pushes the address of the created routine on the stack. CVF does in fact create read-only handles to constants, which is a very good thing, but the mechanism has nothing to do with a prohibition on self-modifying programs, because there is no such prohibition.
