Software Archive
Read-only legacy content
17060 Discussions
Weird rendering glitches since last update
Jan_Willem_K_
Hey forum,
I updated to the XDK version 1878 today and stumbled upon a weird problem.
I'm building an application where in a certain section the app cycles through a couple of images and it shows weird rendering problems.
Some observations
This happens mostly in the Crosswalk build for android but also in the Cordova Android build.
The div's that hold these images that are being cycled through are on top of a layer holding a video that is being hidden after it is done playing.
If I totally strip this video, it glitches less but it still occurs.
It didn't happen before I upgraded the intel XDK so this confuses me a lot.
Details
I'm using a Radxa Rock Pro to test on running Android Kitkat 4.4.2
In the attachments you can see a photo of my TV where this problem occurs. Any insight or help would be awesome! Thanks in advance.
John_H_Intel2
The image you attached looks like a memory issue. What kind of device are you testing on? Have you tested on any other devices?
Jan_Willem_K_
I have tested it on the Radxa Rock Pro.
http://radxa.com/Rock/specifications
I will also test it on my Phone and Tablet to see if there are different results. If it is a memory issue though, is that a problem with the manufacturer or is there a way to tackle such a thing?
John_H_Intel2
Can you create an app based on one of the samples and install it on the device?
How does it perform?
