Software Archive
Read-only legacy content
17060 Discussions
What is the best programming language for mobile apps?
anbu2020
I mainly want to develop Blackberry apps, but I would like to learn a language that is compatible with as many phone platforms as possible.
_________________________________
seo | link building
Yacoubi_M_
I think you can use black berry web works, you can build your application using html5 and Java script and the same code can be used in other platform
Oleksandr_C_
Apparently - Java is the best choice. But you should consider C too.
SergeyKostrov
Valued Contributor II
>>...Apparently - Java is the best choice. But you should consider C too... That is why Google's Android is Java-based ( Why? Portability! ). However, Google later realized that it makes sense to provide some support for C and C++ languages and introduced NDK.
Ricky_J_1
Why you are targeting RIM application, I did'nt say BB isn't good but many people just uses iOS or Android devices. I am working as ipad case designer at http://www.kekacase.com/ , but sometimes I partly develop iOS apps.
Finn_M_
For mobile apps, you have a few options. The first thing to do is decide which platform you wish to develop for, as each uses a separate language. For Android, you will use Java for writing apps, Apple's iOS uses Objective C, and for Windows, you have the most options, being able to use Visual Basic, C# or C++.
I have not yet gotten into Windows development, however there are a lot of opportunities, as it is new, and there are not as many apps out yet. Microsoft is also providing a lot of incentives for developers. Between iOS and Android, I would recommend Android because, as previously stated, Java is free, and has many applications outside of mobile development. In order to develop for iOS, you need to use Objective C, and the only IDE you can use is Xcode, which can only run on a Mac, and does not used for much of anything outside of iOS.
karloswilson
According to me, Java is the best programming language to develop mobile apps for android mobile And C and C# are the best programming languages to develop iPhone App and iPad Apps.
Chirag_Chinmay
Go for Java, C# or Visual Basic as the SDK's provide a better User Interface using these programming languages.
Vidura_Dhananjaya
New Contributor II
c++ and java. c# good for windows mobile apps
Alejandro_J_
Android development is commonly in Java but there are C/C++ options available. IOS development revolves around Objective-C to the best of my knowledge.
Dushan_C_
It depends on the platform. Java for Android, Objective C for iOS and C#/C++ for Windows Phone
Vidura_Dhananjaya
New Contributor II
why you don't try HTML5
Ali_k_2
For black apps I suggest you to create your mobile apps on Java .
Ramith_H_
Use phonegap so that it would be easy for building for many platforms. You can use angular js,ionic framework to make your apps function on these platforms.
Sarah_T_
ASP.NET is best for mobile apps development because it is an open source platform that offers by Microsoft. Mobitsolutions has strong portfolio in mobile applications. Further can visit here: http://www.mobitsolutions.com/mobile-application-development.php
Andrew_J_4
This blog is providing good information. I like it.
Akhil_R_
Java is my opinion. I personally prefer java.
vondes_v_
can i make the app like Mobile Recorder 24 with C#?
Patil__Ritesh
Mobile application development industry in the last five years has multiplied in leaps and bounds, changing the way businesses function worldwide. With enterprises aligning mobile apps to their productivity in the recent times, and with the rapid innovation in mobile devices across platforms; it calls for mobile app developers to write several versions of an application for many different platforms using a single language and many pieces of reusable code.
Once you intend to realize your mobile app idea, it's time to validate it, understand the target market, and narrow down on the platform you ideally would like to build your mobile application on. As soon as that is decided, it’s time to select a programming language, keeping in mind your business strategy to make either native, hybrid, or cross-platform apps. Below are the languages one can use to develop a mobile app.
  1. Java
  2. HTML5
  3. Objective-C
  4. Swift
  5. C++
  6. C#
If anyone is interested in reading about web application development services then click on the link. You will find useful info about web app development.
Jones__David1
I think Java is the best choice
Johnson__Smith
In this digital world, mobile applications are flourishing with each passing day. It is changing the way business function so it is must to have the application for your business. Business entrepreneurs are stepping ahead to develop the application for their business. They are hiring experienced and professional mobile app development company for developing a rich-featured application for their business. But before stepping for mobile app development, it must that the businesses completely analyze the targeted market. Once to complete your market research it's time to choose the programming language.
While choosing the programming language you must keep your business strategy in mind which will help you to choose the best ever platform for your business. You can opt for either native, hybrid, or cross-platform applications. Here is the list programming language which one can use to develop an effective mobile app for their business as it gets rich supported in android devices.
Kotlin
Java
html5
objective-c
swift
c++
c#
The list of the programming language is endless so you can choose any of the languages as per your preference for developing an application for your business. Just keep in mind that your customer must get the best experience while they use the application.
biswal__minati
Python. Python is an object-oriented and high-level programming language with combined dynamic semantics mainly for web and app development. ...
Java. James A. Gosling, a former computer scientist with Sun Microsystems developed Java in the mid-1990s. ...
PHP (Hypertext Preprocessor) ...
js. ...
C++ ...
Swift. ...
Objective – C. ...
JavaScript.
Learn more from Android App Development Course
