Software Archive
Read-only legacy content
Where are license files after installation of Intel® Parallel Studio XE Composer Edition for C++ Linux
Rashawn_K_Intel1
I installed Parallel Studio XE Composer Edition for Linux yesterday. After invoking the environment by sourcing the appropriate compilersvars script, I inspected the environment, and noted the variable $INTEL_LICENSE_FILE:
echo $INTEL_LICENSE_FILE
/<pathTo>/compilers_and_libraries_2016.1.150/linux/licenses
However, when inspecting the above path, I find the path does not exist.  My question is, what should the above path contain?  I received a *.lic file in an email when I first downloaded the software.  Should I copy this file into the installation area?
Rashawn Knapp
Light_Intel
Hi Rashawn,
I assume you installed a named user product on your Linux* system. During the installation the license file should have been put in the following location: /opt/intel/licenses
You don't need to worry about the variable $INTEL_LICENSE_FILE, it needs to be set for floating licenses only.
Noga
Intel Developer Support
Rashawn_K_Intel1
Hello Noga,
Thank you for responding.  I do not have access to /opt/intel/licenses/ as it is owned by root.  I conducted the installation as a user and installed into a shared NFS space. I am confused by the environment variable which has /opt/intel/licenses/ listed second after the path I referenced earlier, which is my installation location. I do not have a floating license.  I need a solution to use this compiler on an NFS space. Is there a way that I can place the appropriate license file(s) in the installation area? Perhaps I overlooked a prompt during the installation for where to place the license.
-Rashawn
Devorah_H_Intel
This article explains how obtain a license file which you can place in the installation directory:
https://software.intel.com/en-us/articles/how-do-i-get-my-license-file-for-intel-parallel-studio-xe-2016
Rashawn_K_Intel1
Hello Devorah,
Thank you for sharing the link.  This is exactly what I needed and  now the compilers work without licensing errors.
-Rashawn
