I installed Parallel Studio XE Composer Edition for Linux yesterday. After invoking the environment by sourcing the appropriate compilersvars script, I inspected the environment, and noted the variable $INTEL_LICENSE_FILE:
echo $INTEL_LICENSE_FILE
/<pathTo>/compilers_and_libraries_2016.1.150/linux/licenses
However, when inspecting the above path, I find the path does not exist. My question is, what should the above path contain? I received a *.lic file in an email when I first downloaded the software. Should I copy this file into the installation area?
Rashawn Knapp
- Tags:
- Development Tools
- Intel® License Manager for FLEXlm*
- Intel® Software Development Products Registration Center
Hi Rashawn,
I assume you installed a named user product on your Linux* system. During the installation the license file should have been put in the following location: /opt/intel/licenses
You don't need to worry about the variable $INTEL_LICENSE_FILE, it needs to be set for floating licenses only.
Noga
Intel Developer Support
Hello Noga,
Thank you for responding. I do not have access to /opt/intel/licenses/ as it is owned by root. I conducted the installation as a user and installed into a shared NFS space. I am confused by the environment variable which has /opt/intel/licenses/ listed second after the path I referenced earlier, which is my installation location. I do not have a floating license. I need a solution to use this compiler on an NFS space. Is there a way that I can place the appropriate license file(s) in the installation area? Perhaps I overlooked a prompt during the installation for where to place the license.
-Rashawn
This article explains how obtain a license file which you can place in the installation directory:
Hello Devorah,
Thank you for sharing the link. This is exactly what I needed and now the compilers work without licensing errors.
-Rashawn
