My scenarios are pretty tough hence I wish to know if anyone by chance might have come across the functions of the sense manager session or interface that would help me realize the features i need.
The first is that I wish to be able to manipulate the points I retrieve from face data. For instance after using the camera to capture a face, I wish to querypoints and after getting the array of points I wish to alter the angles between them. Is there a function for that?
Secondly, can I capture pictures of different objects and display on one screen at the same time? If this is possible can I move the pictures via touch less capabilities or otherwise with the mouse and rearrange them on the same screen?
I would like to work with these for now. If anyone has worked in this domain using C#, I would appreciate greatly.
I don't really understand what you meant by your first question, when you say you want to alter the angles between the facial (Landmark ?) points
In your second application are you referring to object tracking? Please explain your questions ails and mainly as to what you are trying to do in a high-level...
