Software Archive
Read-only legacy content
17060 Discussions
Which plug- in is used in the HelloAdMob example?
Slavi_I_
I'm wondering which plug- in is used in the HelloAdMob example. I mean I see it's floatinghotpot's plug- in but I can't see what is the id of the plug- in and I can't add it to my project. I thought I found the right ID but it didn't work.
Thank you.
PaulF_IntelCorp
I believe the info you're looking for is in the additions.xml file, located at the top of the project directory. If I'm wrong on that point, go to the git repo that contains the plugin you're after and inside the plugin.xml file you'll find the plugin ID.
