Software Archive
Read-only legacy content
17060 Discussions
Why calculation of fibonacci with cilk took longer?
amit_l_
I'm running on Linux (ubuntu) Intel I7 1600Mhz, with 4 cores. I'm using Intel compiler V14 I measured the time it tooks to calculate fibonacci with or without cilk:
int fib(int n) {
    if (n < 2) {
        return n;
    else {
        int x = cilk_spawn fib(n-1);
        int y = fib(n-2);
        cilk_spawn;
        return (x+y);
inf seqFib(int n) {
    if (n < 2) {
        return n;
    else {
        int x = fib(n-1);
        int y = fib(n-2);
        return (x+y);
long long getNanoTime() {
    struct timespec currTod;
    long long curT = 0;
    long long billion = 1000000000;
    clock_gettime(CLOCK_REALTIME, &currTod);
    curT  = currTod.tv_sec * billion ;
    curT += currTod.tv_nsec;
    return curT;
int main() {
    int x = 40;
    long long start = getNanoTime();
    int res = fib(x);
    long long end = getNanoTime();
    cout << "\n cilk: " << res;
    res = seqFib(x);
    cout << "\n seq:" << res;
    return 0;
But the results are weired: With cilk the result is 427 nano and without cilk it tooks 281 nano
I run it for several times, and same results ...
Barry_T_Intel
The classic "fib" program is almost always used as the first example of a Cilk program. It's a really good example because it's really simple and clearly demonstrates the basic concepts behind Cilk programming. It's a really bad example because it's almost entirely overhead. Using the "cilk_spawn" keyword is relatively cheap, but it's not free. Since the program does almost nothing except spawn and sync, the overhead dominates the code. Worse yet, the compiler is *really* good at optimizing the sequential case.
Jim Sukha wrote an excellent pair of articles on this issue:
So  I'm not surprised that you're not seeing speedup. fib() is *the* poster child for Jim's first pitfall: Parallel regions with insufficient work.
   - Barry
