Software Archive
Read-only legacy content
17060 Discussions
Why is performance so poor compared to Cocoonjs?
Michael_P_1
I'm currently working on an HTML5 game and have been using Cocoonjs to create native aps for IOS and Android.  CocoonJs has its problems, most notably no direct AdMob support (they are apparently working on adding that now), but the game's performance once on the devices was pretty good.
I exported the same game to my same Android device via Intel XDK and the games performance was absolutely terrible. It had been silky smooth and had very consistent timing (when exported via cocoonjs).  Once exported via XDK it had an absolutely terrible frame-rate and would alternate between insanely slow and then 2x speed as though it was trying to make up for lost time, yet always with the terrible frame-rate. The game became unplayable.
I thought CocoonJS was based on open-source technology.  Why does XDK compiler create such drastically inferior aps based on the same exact html5 files?
Is this massive performance discrepancy being addressed?
Mike
PaulF_IntelCorp
There is no compiler, your app runs inside an HTML5 webview (think of it as an embedded browser). That runtime engine is provided by the target device, the XDK has no control over it. In the case of Android devices, that embedded browser can be replaced. Most Android devices have awful embedded rendering engines. This is why we provide the Crosswalk on Android option, it provides substantially better performance, at the expense of increased size, because it replaces the embedded webview. Please build your Android game using the Crosswalk build option.
See this blog for more details regarding the webview: http://blogs.intel.com/evangelists/2014/09/02/html5-web-app-webview-app
Michael_P_1
Thanks for the info. I'll give this a try when I get a chance and report back.
PaulF_IntelCorp
p.s. If you are building with Crosswalk, specify version 10 of Crosswalk and make sure your viewport meta tag includes "width=device-width" and "minimum-scale=1" to enable GPU hardware acceleration.
Bill_N_
Hi Paul, I make game from Construct 2 (screen 640,960) then use crosswalk to build android. the result is Fps < 40 so my game is not smooth running or jumping. I tried same source with Cocoonjs webview+ then Fps 50-60 so my game very smooth. I check width and scale and everything is same as your suggestion. Do you have any suggestion for my case? What is different webview between cocoonjs vs crosswalk? Thanks
PaulF_IntelCorp
My understanding is that they are also using Crosswalk as the underlying WebView, but they may have a different version than we do in their build system. Sorry, but I am not privvy to the underlying elements of CocoonJS and their build system, that is proprietary to Ludei and not something we have insight into.
We will have a Crosswalk 11 build available in the near future, you might find better results with that.
Vijay_R_1
Try Importing the below plugin (from Ludei - CocoonJs) in Your XDK Project and test with the Webview+ bundled with this plugin.
https://github.com/ludei/webview-plus/
Barry_Johnson
Vijay - very curious if you have any experience using their WebView+ plugin on the iOS side and what your thoughts are on it. I would love to get out of the iOS standard webview and into something that isn't actively broken as it regards IndexedDB support (which continues to be broken in the base iOS uiwebview and safari itself I believe).
Thanks!
Bill_N_
Vijay, Thanks for your comment. Hope I can so my problem so can release my game soon. I will try and feedback the result even now I am still not able to import it yet?
Bill_N_
Vijay, I have done as below step:
Download your suggest plugin to local and extract to my project folder. from Intel xdk import third party, select import local plugin, select plugin folder in my project path. Build crosswalk and get apk file then install on my phone for testing. The result is same as before Fps < 40.
Is that way correct?
DIA
Cocoon uses a native canvas graphics implementation named CANVAS+. It does not uses a complete webview, cocoon is totally focused on canvas, that is why it is so fast for HTML5 Canvas Games.
PaulF_IntelCorp
There is an issue with the "skia" library in the recent Chromium releases that impacts the Crosswalk performance. A fix for that issue is in the works, but is not yet available. When that fix is available it will be part of a new version of Crosswalk and will be available in the XDK. Sorry, but I don't have a timeline for when that fix will be implemented and available in the build system.
PaulF_IntelCorp
I believe Crosswalk 15 is the target for the fix.
PaulF_IntelCorp
There is a solution coming for that, very soon.
PaulF_IntelCorp
@matrix -- the other option, that slimmed down Crosswalk project, is just an experiment, it's not something we can use. At this point they have not made the commitment to turn it into a serious project.
Yes, the shared model is the solution we're offering for a smaller APK, it is now available in the 2170 release. Very aware of the shortcomings of this solution, see this doc page: https://software.intel.com/en-us/xdk/docs/choosing-crosswalk-build-options-shared-or-embedded
Jacques_L_
Just started with IntelXDK. I use Construct 2 for games.
Is it just me, or are the games very slow on Android? Is there a way to get this solved?
Thanks in advance
Jacques
PaulF_IntelCorp
Please build with Crosswalk, the standard Android webview is not appropriate for Construct2 games. See these articles for more details:
Jacques_L_
Thanks Paul, but tried that already, no luck... still laggy, and not just with one project, all of them (10 different games)
Does Intel have something like Canvas+, or DirectCanvas?
PaulF_IntelCorp
Crosswalk is the solution that nearly all the other Construct2 users have been building against. For comparison, what happens when you build for Crosswalk 7? That is the one that most claim they get the best performance from. Are you building for Crosswalk? If you are previewing with App Preview, using the Test tab, you are NOT using Crosswalk (confusing, I know). If you use the Debug tab you ARE using Crosswalk. The Debug tab will adjust to match the version of Crosswalk you select in the Crosswalk build settings.
If things are laggy with Crosswalk 7 or 14 then there is something else going on...
Jacques_L_
Hi Paul.
Crosswalk 7 solved the issue! Thank you!
Andrea_C_
@Jacques, could you please tell me if you see any regressions on Crosswalk 14? You can use the shared beta mode available in the latest version of XDK.
