I am running Intel Optimized MP LINPACK in a new server with 1 Intel Xeon Coprocessor
I run ./runme_offload_intel64 in benchmarks/mp_linpack/bin_intel/intel64 but it shows:
Why it shows: mic03 : COIProcessCreateFromFile result COI_ERROR
What's the reason?(MPSS is running).
Thank you for your answer.
Hi Rancho,
Unfortunately, the error COI_ERROR doesn't specify what exactly the problem is. You may try to restart mpss and see if the problem is gone:
# service mpss restart
What OS and MPSS version are you using? Thanks.
Hi Rancho,
loc-nguyen (Intel) wrote:
Hi Rancho,
Thanks! I uninstalled MPSS and installed it again, and it works!
Thank you
