Software Archive
Read-only legacy content
17060 Discussions
WinNT install into Core 2 duo processor
eliyanto
Hello all,
I haveobsolete OEM software application for mechanical engineeringwhichrunning on Penthium III computer withWindows NTO/S.We want to keep OEM softeare application and to upgrade the computer to the latest version(Core 2 Duo Processor computer) to make faster.BUTthe WinNT didn't succeed to be install on latest computer. I know that WinNT is 32-bit O/S while Core2duo is 64 bit.
Q1: Is there anyway to speed-up the computerby replacing with the latest computer or modifying the processor or whatever ?
thanks
el
David_O_Intel1
WinNT should install fine on Core 2 Duo. There must be some other reason that the installation failed. Perhaps you could review the failure messages in more detail to see exactly what the problem is.
Virtualization could become part of your solution, of course. After installing a hypervisor (VMM), you could create a WinNT guest (VM) to run on it. Running legacy operating systems and software environments is among thekeyuse casesmotivatingvirtualization.
David Ott
yuhong2
Unfortunately because of a problem in NT 4 by default it doesn't. Try finding a BIOS option to limit CPUID max value to 3. Pre-SP6 NT 4 had problems if maximum CPUID value returned by CPUID leaf 0 exceeded 3.
See this for more info on this and other problems in the NT 4 CPUID code:
http://geoffchappell.com/studies/windows/km/cpu/index.htm
xsuperstore
Quoting - yuhong2
Did you recive any error, blue screen ?
