Software Archive
Read-only legacy content
17060 Discussions
Windows Hello is working with the F200!
AndreCarlucci
Hi guys!
For those using Windows 10 already, you can enable the Windows Hello downloading and installing this driver:
https://downloadcenter.intel.com/download/25044/Intel-RealSense-Depth-Camera-Manager-DCM-
Go to "sign in options", enable the PIN option for sign in. Close the window, open again and lo and behold, the "Windows Hello" options will be there!
Just look at your lockscreen to unlock your Windows ;)
Rio_N_
I have installed version 1.4 on windows 8.1 64bit. i finish the installation but error during download some component.
Not problem, i can use this driver to running new madagascar and Warrior Wave game and build program with unity. Maybe my internet connection is lost.
Thanks !!
AndreCarlucci
Well, try again later and let us know if it worked :)
Chris_M_2
Hi. Not sure if you can help or not. I've downloaded this driver (I have a Dell AIO system with integrated F200 camera, was Windows 8.1  but just upgraded to Windows 10 & Windows Hello isn't working - yet) but I have a problem with the install. I run the file and get to the part where it confirms directories etc. but it says, in red, "76MB required 0.0B available" and won't let me continue (the next button is greyed out). Needless to say I have plenty of spare space on my C: (821GB to be exact).
Any ideas? Thanks.
Ariska_Hidayat
Hi Crist,
Say also been the issue. but I am just repeating a few times and then after that run normally. I think the effect of the upgrade from Windows 8.1 to Windows 10.
