- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Could someone please help me in fixing this build issue. I am trying to give a build for windows phone 8.1 from intel xdk. It fails saying as below:
Command finished with error code 2: cmd /s /c "...\Howmuch\platforms\windows\cordova\build.bat --release --verbose --phone"
ERROR building one of the platforms: Error: cmd: Command failed with exit code 2
You may not have the required environment or OS to build this project
at ChildProcess.whenDone (D:\Developer\cordova\5.1.1\node_modules\cordova\node_modules\cordova-lib\src\cordova\superspawn.js:134:23)
at emitTwo (events.js:87:13)
at ChildProcess.emit (events.js:172:7)
at maybeClose (internal/child_process.js:818:16)
at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
I have attached the screenshot of XDK build log page and detailed error log. Please review and advice ASAP.
Sam Deepak.
- Теги:
- HTML5
- Intel® XDK
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Sam, need to look one line further back in your build error log for the answer:
package.phone.appxmanifest(20,78): error APPX3207: App manifest references the wide 310x150 logo image 'images\Wide310x150Logo.scale-240.png' which is larger than the maximum image file size. It must be no larger than 204,800 bytes. [...\Howmuch\platforms\windows\CordovaApp.Phone.jsproj]
One of your image files is too big.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Paul,
I skipped 310x150, 434x210, 744x360 sized images (from launch icons), then it worked. Can you advice if there is any problem I would face due to this.
Sam Deepak.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Paul,
After building it without any error by skipping images that created error, now the app crashes on launching it. The app has been built for windows phone 8.1.
Could you please advice what could be the reasons for crash.
Sam Deepak.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
We're still working out why some apps crash with Windows Phone 8.1 builds. So far it appears to be something about the IE11 Mobile webview that Cordova uses when building for WP8.1. It appears to be very sensitive to the version of jQuery you use. Are you using App Designer to create your app? Does your app include jQuery?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Paul,
Yes, I am using jquery 2.x version. I did not use App Designer, I am using Intel App Framework.3.0. But I created a test app by a Hello World template example., It loads fine, but on click of a button, I am running a javascript to alert the user which is not working, but I changed it to change the color which is surprisingly working.
I am quire confused. Can you please advice.
Sam Deepak.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
The alert() function does not work in the Windows device webviews... so you won't see any alert messages. I found this shim library, which might help (https://github.com/MSOpenTech/winstore-jscompat), but I haven't had time to check it out and see how well it helps.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Paul,
I have placed the script you suggested (winstore-jscompat) before all scripts in the html page, it solved the crash problem. Thanks Paul, If there is any other issue I am going to face, I will come back.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thanks for the feedback, Sam. I hope to do the same test with a few other apps I have here that are failing, very hopeful that the script will resolve this problem for those apps, as well!
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I'm getting the same error in XDK (no Visual Studio).
I've tried reducing icon images size (in Kb.,,, are less than limit indicated), but still no way to build app for windows phone.
Otherwise Windows App works fine, but I need to get WindowsPhone App.
Any suggesion?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Stefano - There are many reasons you might get a build failure. Please attach your full build log.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I sent log file transcription in p.m.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Please skip 310x150, 434x210, 744x360 sized images (from launch icons), then it should work. This is what I did and worked for me.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Intel XDK doesn't allow to skip them.
I've even tried to remove from configuration file, but while building it recovers and use the previous version of 310x150, 150x150 images.
I don't know what other ways try to get app for Windows Phone built
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Please delete the previous build from the app dev center. here you go https://appcenter.html5tools-software.intel.com/csd/controlpanel.aspx . And then after deleting the builds, give a fresh build and see if it works.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Done also this, but nothing changes.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Stefano - It looks like your icon images are too large. The first error in your build log is:
package.phone.appxmanifest(20,78): error APPX3207: App manifest references the wide 310x150 logo image 'images\Wide310x150Logo.scale-140.png' which is larger than the maximum image file size. It must be no larger than 204,800 bytes. [...\i-Wed\platforms\windows\CordovaApp.Phone.jsproj]<br>
We changed our build system last week and published a new XDK version yesterday (3088). We made changes that help our tools work better with Windows icons and splashscreens. I recommend upgrading your XDK version and build again. As always, be sure to create backup copies of your projects before upgrading.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Pamela,
I saw these error, but my icon files have right dimensions in pixels and are smaller in bytes.
I've upgraded to last version released yesterday, but I still get the same issues.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
