Software Archive
Read-only legacy content
Windows phone app test store
dc_l_
Hello the official test of windows store gives me the following error:
What should I do I can change and save as UTF-8 as I do?
The app was created with windows 8 build and everything else is fine except this error.
File encoding test
FAILED
UTF-8 file encoding
  • Error Found: The UTF-8 file encoding test detected the following errors:
    • File www\cordova_plugins.js is not properly UTF-8 encoded. Re-save the file as UTF-8 (including Byte Order Mark).
    • File www\app_framework\appframework.js is not properly UTF-8 encoded. Re-save the file as UTF-8 (including Byte Order Mark).
    • File www\app_framework\appframework.ui.js is not properly UTF-8 encoded. Re-save the file as UTF-8 (including Byte Order Mark).
    • File www\app_framework\pageChangeRepeater.js is not properly UTF-8 encoded. Re-save the file as UTF-8 (including Byte Order Mark).
    • File www\app_framework\themeRelease.js is not properly UTF-8 encoded. Re-save the file as UTF-8 (including Byte Order Mark).
Jerroyd_M_Intel
Hi dc. l,
It looks like you're experiencing the same problem described here: https://software.intel.com/en-us/forums/intel-xdk/topic/623410
Try re-saving the files mentioned as UTF-8 and that will fix your problem
--Jerroyd
dc_l_
Ok, tnks for link. I think I have found a way to save the files. regards
