Software Archive
Read-only legacy content
17061 Discusiones
XDK BUILD SERVER resting periods?
New_Japan_A_
Principiante
1.651 Vistas
ok this is quite funny to say, but i've noticed that the build server stops working after 14:30 pm (GMT+9 tokyo), why i say this?
well my work ends at 5 pm here, and everyday when i try to compile after 4:30pm the compile never ends, the green thing just keep spinning and never finishes the compilation, right now it is 4:49 pm and the compilation i started at 4:31 hasnt stopped spinning.
happens on windows, and mac, both never finishes it so i have to cancel at 5:00 when i leave my office, dont know until when this lasts, but next day seems to work fine again until 4:30.
very weird!
0 kudos
13 Respuestas
New_Japan_A_
Principiante
1.651 Vistas
tested on different computers / internet connections.
Flemming_P_
Principiante
1.651 Vistas
What ??? Build not working .. just the green-spin
Here in europe at 9:20 ... cant be right... there must be a problem
Maybe there should be a status/service info from intel
New_Japan_A_
Principiante
1.651 Vistas
and no answer xD our devs must be on vacations!
and today its happening again! 4:53pm and the build i started at 4:20pm or so, hasnt finished spinning haha
John_H_Intel2
Empleados
1.651 Vistas
Can you be more specific as to which platform(s) are failing to build? Each platform is built from a different server, so it would be helpful to know WHICH platform and name of the app that is failing.
New_Japan_A_
Principiante
1.651 Vistas
yup, ive done more extensive testing on the compiling issue, it happens only on ios builds, and it happens dialy, from 4:30 pm (GMT+9), used 10 computers, different setups (mac, ios, virtualized) different internet connections (ground, wifi, LTE, 3G) and all computers gets stuck on the spinning green thing, after 15 to 20 minutes building, it ends in a build failed "unknown error" screen.
the problem isnt the build because at the next morning the same projects gets compiled successfully without touching anything.
this is interesting and curious issue!
John_H_Intel2
Empleados
1.651 Vistas
What email address are you building with? I dont see this account having a ton of failed builds recently, only 6 so far this month.
New_Japan_A_
Principiante
1.651 Vistas
i posted last week and now it seems it didnt posted at all lol
ok the fact is, im using this very same email, and perhaps the system isnt showing the failed builds because i get tired of waiting and close the process, thus not letting the application display the error dialog, (wich says, an unknown error, so not really helpful)
as for today, i let the builds consecutively fail since 4:30 pm to 5:30 pm (right now) you will see 5 fails in a row, the fifth still is spinning but i will let it finish and display the error log so you can trace the problem with the build server or get a clue on what is happening on this weird issue haha.
hope the gathered data on my build list sets some light about this, because it keeps happening, everyday, at the same times.
p.s. the last build i said has just finished, and of course it failed, this message displays:
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
as i said before, it is not faulty assets since i can keep building the very same project without tampering anything on it at morning, until 4 pm when it starts to fail again.
John_H_Intel2
Empleados
1.651 Vistas
Looking at the build logs and your email address, I was able to deduce there is SoMeThInG going on in the wee hours of the morning with the iOS build servers.As of right now, I cant offer you any advice. We are going to attempt to dig into it, but need additional data from another failing session. So if you want to help, fail a bunch of builds tonight :)
Tomorrow we hope to investigate and see what is going on.
Thanks!
New_Japan_A_
Principiante
1.651 Vistas
ok so today i started the builds at 4 pm (gmt+9) and the fails started at 4:30pm, i did 4 failed builds and had to stop (a dear person passed away, i had to leave the place immediately.. :(. ) but at least i did those 4, if needed i will set more tomorrow at the same hours. hope it helps.
John_H_Intel2
Empleados
1.651 Vistas
Thanks, our developers are looking into it.
Mauro_N_
Principiante
1.651 Vistas
I have a problem when wanting to compile my project when I upload the files , never ends and I can not compile .
Please I need you to help me because I have to deliver a work in which I am cooperating and I'm retracing much .
Thank you
John_H_Intel2
Empleados
1.651 Vistas
Are you still having this issue?
How big is your project?
Leonid_B_
Principiante
1.651 Vistas
And again... What's the problem?
The customer is angry, and thinks I'm bad worker.
But I really just can't finish my iOS build. Green spinner rotates about half of a hour and nothing happens.
Project weight is small: about 4mb, code without errors.
Restarting XDK can't help.
UPD: Now all builds correct, but sometimes problem apperas as before.
P.S.: Sorry for bad english.
Responder
