Software Archive
Read-only legacy content
17061 Discussions
XDK and intel.com login
Swati_S_Intel1
Update :
Hello Intel XDK and forum Users,
As of today (June 26, 2015) we have finished the migration of Intel XDK accounts and we switch completely to the Intel.com login system. You will see a new login screen while logging into the XDK, other than that there is no difference for most users. We  have migrated almost all active users  to the new system as communicated earlier. There are a few active users accounts that we could not automatically migrate though, primarily because intel.com login system does not allow certain characters in the usernames.  Also, we could not migrate your account if you haven’t used XDK in last 3-4 months. We will need to manually migrate these accounts. So, if you find that you cannot login with your existing account, please private message on this thread with your username and  email and we will guide you through the steps to get your account reactivated/setup.
Intel XDK team.
In an effort to unify Intel XDK users accounts completely with Intel Developer Zone (and intel.com),  part of our final phase of migration is starting today.   So far, we have (mostly) silently enabled new and existing XDK user accounts access intel.com and Intel Developer Zone.   Starting today, we will be providing the existingIntel Developer Zone (IDZ) users access to Intel XDK.  In doing so, you may get confused as to whether to use your old XDK login or the IDZ one.  To avoid login confusion, here are the possible scenarios, it will help you understand your particular case. You fall into one of these 4 categories – the first three require nothing extra for you to do.
  1. You have an existing XDK account (but do not have IDZ account) – We have created an IDZ account with the same username as your XDK account and you can log into XDK and IDZ both using this account.
  2. You are a new user and you registered for Intel XDK – Along with your XDK account creation you get access to IDZ using the same credentials
  3. You have an existing IDZ account (but no XDK account) - you will be able to login into XDK using your IDZ credentials after you accept the terms and conditions on XDK login page
  4. You have existing XDK account and existing IDZ account –
    1. If you had same login username and password for XDK and IDZ account you will continue to use the same for both
    2. If your usernames for XDK and IDZ accounts are same but passwords are different – you will be prompted to merge your accounts and enter your intel.com password. After you enter “validate and Merge”, you will be able to use this credentials to log in into both XDK and IDZ.
    3. If Your XDK username and IDZ usernames were different –
      1. Now you have two intel.com accounts, You will be able to login into IDZ using both credentials
      2. You will be able to login into XDK using your existing XDK username as usual and also using your IDZ account credentials after you agree to terms and conditions on XDK login page
      3. When you login into XDK using your IDZ account credentials, it’s going to be a new XDK account so you will not be able to access your existing project or certificates during that login session, so it is recommended that you continue using your current XDK account credentials so you have access to your existing projects and certificates.
-Intel XDK team
David_K_3
Thanks for the communication on this and being dedicated to providing info and help upfront...
Best,
David
İhsan_T_1
Hi Swati,
I think there is a problem originating form my account:
XDK ver. 1912. (re installed many times, problem does not go)...
Done my project settings and then at the build tab:
I try to build, it shows a dialogue saying: "Loading Build Server UI". The dialogue disappears and nothing happens.
The build tab contents go unresponsive until I press "Close Build Page" button.
Swati_S_Intel1
Hello Ihsan,
Please follow the other thread you've posted for the build issue.
Swati
Ian_Devlin
Good idea, it's always a faff to have different logins floating about, especially for the same organisation.
