Software Archive
Read-only legacy content
17060 Discussions
XDK error build WP
Ernani_Torquato
Hi, I need help, I'm trying to compile a project in the XDK 3400 for windows phone with CLI 5.4.1, but the project shows the error as the log.
I have attached the log file.
thanks.
PaulF_IntelCorp
There are several error messages in the log that indicate that your pathnames are too long. I don't know specifically which files in your app are causing this problem, but it would be those files that are under the www directory in your project folder. Might be the names and locations of your icons and splash screen files?
An example error which points this out:
...\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets(2515,5): error MSB4018: System.IO.PathTooLongException: The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters. [...\appMobile\platforms\windows\CordovaApp.Phone.jsproj]
PaulF_IntelCorp
Ernani_Torquato
Very good, I had selected different paths and not realized. Thank you for your help.
Pablo_A_
Friend , I have no problem to generate the App , but to publish it in the Microsoft store, you can help me , I've tried everything , read the documentation , but I can not publish the app .
