Software Archive
Read-only legacy content
XDK freezes at startup
Santtu_I_
I have had now 2 days problem with starting XDK. I think it the problem started with build 3400?
It starts up to where I can see my projects, and then it freezes, I have tried waiting there for 1 hour, and still nothing happens when I click anything.
I have tried to reinstall using the repair, and even a uninstall with the remove everything check box selected.
I do not know what to try next...
br,
Santtu I.
Rakshith_K_Intel
Here is some information on how to clear all cache directories and clean all xdk related files, you can try this:
https://software.intel.com/en-us/xdk/faqs/general#recover-xdk
Uninstall and then follow the instruction in the above FAQ "How do I recover when the Intel XDK hangs or won't start?"
Rakshith_K_Intel
Santtu_I_
Thank you, deleting the folder contents of %AppData%\..\Local\XDK did the trick!
