Software Archive
Read-only legacy content
17060 Discussions
XDK install to linux32 arm
Daniele_S_2
I tried to install XDK on arm, the install.sh file by mistake because the variable CPU_FAMILY remains empty since there is the field "family" in "/ prioc / cpuinfo"
I disabled the control of the cpu and forced mode cli.
When he goes to call the program "./pset/32/install_cli.32" comes with the following error:
"Syntax error:" ("unexpected"
I think it's due to the fact that the program has been pre-compiled for x86 and I wonder if there is a version ARM so that it installs.
Thank
Rakshith_K_Intel
There is no ARM specific version, the Intel XDK is expected to run on X86 machines. We will look into the CPU_FAMILY variable, thanks for reporting.
Daniele_S_2
is written somewhere on the site ?
The file install.sh should signal that you can install on arm .
I hope you edit the file .
Why was chosen policy not to install it on arm ?
thanks for reply
good life
