- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I've got a 3120A in a workstation chassis and it runs on Windows fine. However when idling at temps of at 52-55C and drawing ~100W power, the fan seems to continually switch on for a few seconds then off again for a few seconds. The case has plenty of fans and sits under the desk in an air conditioned office @ 72F.
As the blower fan is quite whiney it's pretty annoying how it cycles in/out under no load but i can't find a way of tuning up the thresholds for active cooling as you can on GPUs. Or would disabling it (micctrl --shutdown) when not in use help?
Any thoughts?
Cheers,
Simon
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The datasheet (http://www.intel.com/content/www/us/en/processors/xeon/xeon-phi-coproces...) discusses how cooling is controlled.
In any event, such controls are inherently dangerous and I recommend against tinkering with them.
Looking at your wattage, you are not dropping below C1. To say it another way, you are not dropping into the package C-states. This can be happening for a variety of reasons, such as something is pinging the coprocessor and keeping it from dropping into a lower C-state, or that you disabled the package C-states. Run micsmc and look at the "advanced" page. It will tell you if you have package C-states enabled.
The idling temperatures are comparable with what I'm getting here. Note that monitoring SW, including micsmc, will keep the processor "awake" and prevent it from dropping into package C states.
Taylor
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It sounds like you are using it with windows. You can use micctrl to turn it off and the fan will quit coming on so much.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
