Software Archive
Read-only legacy content
Xeon Phi Works but Flash and SMC versions unavailable
Rakib
I am using a Xeon Phi 3120A.
It is working but with an issue that according to the documentation can lead to erratic behavior. Currently I am using mpss3.1 on RHEL 6.4.
When I run micinfo, following is the output:
MicInfo Utility Log
Created Wed Nov 13 16:01:03 2013
    System Info
        HOST OS            : Linux
        OS Version        : 2.6.32-358.23.2.el6.x86_64
        Driver Version        : 3.1-0.1.build0
        MPSS Version        : 3.1
        Host Physical Memory    : 32826 MB
Device No: 0, Device Name: mic0
    Version
        Flash Version          : NotAvailable
        SMC Firmware Version     : NotAvailable
        SMC Boot Loader Version     : NotAvailable
        uOS Version          : NotAvailable
        Device Serial Number      : NotAvailable
    Board
        Vendor ID          : 0x8086
        Device ID          : 0x225d
        Subsystem ID          : 0x3608
        Coprocessor Stepping ID     : 2
        PCIe Width          : x8
        PCIe Speed          : 5 GT/s
        PCIe Max payload size     : 256 bytes
        PCIe Max read req size     : 512 bytes
        Coprocessor Model     : 0x01
        Coprocessor Model Ext     : 0x00
        Coprocessor Type     : 0x00
        Coprocessor Family     : 0x0b
        Coprocessor Family Ext     : 0x00
        Coprocessor Stepping      : C0
        Board SKU          : C0 QS-3120 P/A
        ECC Mode          : NotAvailable
        SMC HW Revision      : NotAvailable
    Cores
        Total No of Active Cores : 57
        Voltage          : 0 uV
        Frequency         : 1100000 kHz
    Thermal
        Fan Speed Control      : NotAvailable
        Fan RPM          : NotAvailable
        Fan PWM          : NotAvailable
        Die Temp         : NotAvailable
    GDDR
        GDDR Vendor         : Elpida
        GDDR Version         : 0x1
        GDDR Density         : 2048 Mb
        GDDR Size         : 5952 MB
        GDDR Technology         : GDDR5
        GDDR Speed         : 5.000000 GT/s
        GDDR Frequency         : 2500000 kHz
        GDDR Voltage         : 0 uV
When I updated the Flash and SMC, following was the output:
$ /usr/bin/micflash -update -device all
No image path specified - Searching: /usr/share/mpss/flash
mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_C0_0386-03.rom.smc
mic0: Flash update started
mic0: Flash update done
mic0: SMC update started
micflash: mic0: SMC update failed: SMC buffer size exceeded (0x1)
mic0: Transitioning to ready state
Please restart host for flash changes to take effect
Please help.
Kevin_D_Intel
I can't speak as to why this appears only in the MPSS 3.1 windows-readme.pdf (available on the Intel® Manycore Platform Software Stack (MPSS) page), but that very error is mentioned at the bottom of page 4 (in step 4 of section 2.2.3 Update the Flash) and the suggestion is to proceed with the other steps in that section.
You should at least first reboot your host, then boot your card (if you had not previously set it up to boot at host reboot time) and then use micinfo to check all the flash/SMC levels.
Here are the Flash/SMC versions for MPSS 3.1 under a Linux system:
        System Info
                HOST OS                 : Linux
                OS Version              : 2.6.32-358.el6.x86_64
                MPSS Version            : 3.1
                Host Physical Memory    : 5979 MB
        Version
                Flash Version            : 2.1.03.0386
                SMC Firmware Version     : 1.15.4830
                SMC Boot Loader Version  : 1.8.4326
                uOS Version              : 2.6.38.8+mpss3.1
If Flash/SMC versions on your card are not at expected levels, then you could try the flash step again (as per the Linux readme-en.txt), or try updating the Bootloader flash only as per the specifics in the windows-readme.pdf starting at step 6 of those instructions. If they are at expected levels then the card should be good to go.
Rakib
Hi Kevin,
Thank you very much for your reply. I just tried to follow the steps from that file.
In step 7, I get the following error.
$ micflash -update /usr/share/mpss/flash/EXT_HP2_SMC_Bootloader_1_8_4326.css_ab -device all
mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_SMC_Bootloader_1_8_4326.css_ab
micflash: mic0: SMC update not permitted: Unknown error (0x0)
Kevin_D_Intel
Are you operating under the root account or at least a sudo shell?
So you rebooted the host first and checked the Firmware/SMC levels? and the result was still the same as before?
What happens when you:
1. Reset the card (micctrl -r)
2. Verify the card is "ready" (micctrl -s)
3. Boot the card (micctrl -b)
4. micinfo
Kevin_D_Intel
I just ran into a similar failed flash on Windows and once I was able to boot the cards the Firmware/SMC versions all reported NotAvailable.
If you have not had any success yet, you might try:
1. Shutdown the host and physically power cycle the host
2. Reboot the host, and reset the Xeon Phi card.
3. Ensure the card is in the "ready" state and then repeat the original micflash (as root): /usr/bin/micflash -update -device all
When I repeated the flash both the Flash and SMC succeeded where previously the SMC flash had failed.
Rakib
Hi Kevin,
Yes, I was on a root shell.
I tried all the steps from your last two comments. Still shows the same errors.
One thing I probably should have mentioned. Before using mpss-3.1, I used mpss-2.1 .
But even then I couldn't see the Flash/SMC version.
I never was able to see the Flash/SMC version since I purchased the card.
Could it be a faulty card? In that case, what should I do?
Frances_R_Intel
One thing I noticed in your original post is that you have a C0 stepping. For C0 cards, you do not update the bootloader as a separate step. That is why it was saying "SMC update not permitted: Unknown error (0x0)". Instead you should run the first command you tried: "/usr/bin/micflash -update -device all" twice. It is expected that you will get the message "No image path specified - Searching: /usr/share/mpss/flash". That is telling you that you did not explicitly specify a flash file, so it is going to look in the default location for the correct file - which the next line shows it did find. It is normally OK that you get the message "SMC update failed: SMC buffer size exceeded (0x1)". I don't know why but this is a known bug and you get this even when the update finished successfully.
The micinfo command will not show you the flash version unless the card is booted - i.e. if 'micctrl -s' shows online. If you can't see the information then, there is a problem.
So make sure the card is in the ready state: "micctrl -rw"
Try doing "/usr/bin/micflash -update -device all" twice in a row
Reboot the host
Check to see if the card is online: "micctrl -w" and if not boot it
Then rerun micinfo.
If it still will not give you the flash information, with the card online and you running as root, there is a problem.
Rakib
Hi Frances,
Thank you for your reply.
I just ran all the things in the order you mentioned. But still Flash/SMC versions are not available.
So there must be a problem with the card. Should I contact Intel support to replace the card?
Frances_R_Intel
As a software person, I really, really, really would have liked to find a nice, simple software solution, And maybe there is and I just don't see it. But given that this has been an ongoing problem, maybe it is time to talk to support and see what they say.
