Software Archive
Read-only legacy content
17060 Discussions
You can temporarily disable this error with android.enforceUniquePackageName=false
Leonidas_S_
I get below during Android build… I have Admob and Google Analytics Plugins, and some others... I build using XDK... what to do?
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':processReleaseResources'.
> Error: more than one library with package name 'com.google.android.gms'
  However, this is temporary and will be enforced in 1.0
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 10.2 secs
Leonidas_S_
https://github.com/danwilson/google-analytics-plugin
removed this and compiled correctly... well if want admob and analytics by Google - what have to do????
Anusha_M_Intel1
It looks like a particular library is duplicated in both plugins causing the build failure. I will report this to engineering to see if something can be done on our side.
The alternative admob plugin by floatinghotspot also seems to the failing with the same error.
Leonidas_S_
Please notify here,.... when you fix bug...
may fork plugin in github and modify it in my account?
Another matter
these admob banner ads designed for games... ? I found that if my page scrolls... in other words is not a game and is not fit in the viewport, REQUIRES SCROLLER, BANNER is not fixed like a fixed to bottom nav bar in Bootstrap, in case if scroll half way banner moves to the middle of screen hiding content... well?
Anusha_M_Intel1
No. I have tested admob on non-game apps several times and have not encountered the kind of behavior you are seeing. It should be a fixed banner at the bottom. Check out the Hello Admob plugin that ships with the XDK. You will see how it should look. Build app and test on phone. The sample is not compatible with Windows at the moment.
Leonidas_S_
this is corrected code for fixed bottom banner? May my problem is due to Bootstrap 3.3.5 used and have two nav bar fixed - one on top and one on bottom...? Or...
            var bannerAdUnit = "ca-app-pub-000000000000000";
            var interstitialAdUnit = "ca-app-pub-000000000000000";
            var isOverlap = true; //true: overlap, false: split
            var isTest = false;
            window.admob.setUp(bannerAdUnit, interstitialAdUnit, isOverlap, isTest);
            window.admob.showBannerAd('bottom-center','SMART_BANNER');
Leonidas_S_
I will test sample from XDK for admob
You fixed PLUGIN CONFLICT... ? If not when you will do so...?
Anusha_M_Intel1
Engineering is looking into it Leonidas. It is also the holidays and so things will pick up in January. I can provide a better response then.
Leonidas_S_
OK
Leonidas_S_
js code for Admob in xdk differs between different Plugins...?
Leonidas_S_
Uncaught TypeError: Cannot read property 'setOptions' of undefined index.html:324
initAd index.html:324initApp index.html:296Channel.subscribe cordova.js:754document.addEventListener cordova.js:131onDocLoad index.html:287onDeviceReady index.html:247Channel.fire cordova.js:816(anonymous function) cordova.js:229
line 324
            window.plugins.AdMob.setOptions( {
                publisherId: admobid.banner,
                interstitialAdId: admobid.interstitial,
                bannerAtTop: false, // set to true, to put banner at top
                overlap: false, // set to true, to allow banner overlap webview
                offsetTopBar: false, // set to true to avoid ios7 status bar overlap
                isTesting: false, // receiving test ad
                autoShow: true // auto show interstitial ad when loaded
I tried unsuccessfully (first run admob sample success app xdk) to migrate the code from this... after went here >>>
https://github.com/floatinghotpot/cordova-plugin-admob/blob/master/test/index.html  and getting error above...
is the same plugin as in origin xdk sample admob app???? I am not getting cordova alert (plugin run)choose failure/success but getting error above... well?
Leonidas_S_
Leonidas_S_
#9
ANY NEWS FIXED...?
