Software Archive
Read-only legacy content
17060 Discussions
project rebuild error - #11012
yeo_s_
I am just starting to learn how to program Intel PHI card.  I have recently written the 1st and a very simple program (to copy some array from host to card memory) but unable to rebuild successfully.
Development environment details:
-  Operating System: Windows Server 2012.
-  Compiler: Intel Compiler 2016.
-  Visual Studio 2013.
-  Programming language: C++.
-  Intel PHI card model: 6GB memory, 1.1GHz clock speed, 57cores.
-  I have installed relevant drivers for window OS as per Intel guide.
I can compile above code, but unable to build successfully.
Error msg: ip:
-  warning #11012: "MIC" unable to find -lifcoremt.
-  klom-mpu-Linux-ld.exe: cannot find -lifcoremt.
Does anyone know how to resolve this issue?  Thks.
sh__yeo
Just to check if anyone has any advice/answer to the following (whether it is due to installation, or some user settings in VS2013 IDE, or other reasons)?  I also encountered the same linking error when I tried to build some of the sample projects (from Intel) under the Intel Compiler directory.  Thanks.
