Software Archive
Read-only legacy content
17060 Discussions
You cannot drag and drop these widgets in App Framework 7
Jayaram_K_
Intel XDK Version 3491 on Windows 10 Pro.
Accordion
Input
ListItem
Media Item
Select
Checkbox
Slider
Text Area
Swipeout
Can someone check this out in Version 3491, please?
Hamilton_Tenório_da_
Valued Contributor I
As far as I konw, in order to use some UI elements, you must first drag a List block element to the desired position in the layout. The slider, checkbox and other UI elements can only be inserted into the List block element at this time.
PaulF_IntelCorp
As Hamilton correctly points out, Framework 7 is very sensitive to the order in which you apply elements. For simplicity sake, I recommend you use Bootstrap, it is the easiest to use and apply. Framework 7 takes a lot of time to learn.
Jayaram_K_
I did try it with a List Block element. It would show in the code but not in DESIGN. I only tried the Media Items widget.
